Lamborghini Aventador Roadster - Detailed by Lawrence
Awesome work, even more awesome car! Now I'm not doubting or even questioning the reasoning behind the design of the car, but that wheel to fender gal in the front is HUGE!! Rear is nice and close to tucked, but the front looks like off road clearance, lol
I was JUST thinking that man. Seems it should be tight so when you are under hard acceleration, it would raise some. BEAUTIFUL car and great job man. Just curious, with a customer owning one of these, what does one get paid for 38 hours of labor??
Thank you all very much for your kind words.
For those of your concerned about the front wheel gap, I did state the following in the original write up
And here are some after shots that I took. It was about to start raining and I was in a hurry and inadvertently left the nose raised - kinda messed up the after shots, but it is what it is....
The car has a function whereby you can raise the front end to deal with speed bumps, and I had it raised to get in and out of my garage (there is a little 'ramp' leading into the entrance) and simply forgot to re-lower the car before the after shots. :doh:
I can assure the front end wheel gap is a low as the rear with the nose down.
:dblthumb2:
