Michael Stoops
- Sep 14, 2009
- 86
Our Ultimate Wax (liquid or paste) would be considered a sealant because it is 100% synthetic man made polymers. Sealant is nothing more than a synonym for "synthetic wax" and does the same thing that carnauba wax does, just in a slightly different way.
As a general rule of thumb, synthetics will last longer than carnaubas will, but obviously just as some carnaubas last longer than others, so too do some sealants last longer than others. But generally speaking, synthetics last longer than carnaubas. There is no real "need" to use both but some people do it just for the looks of the carnauba (if they can actually see a difference, that is) but the protection of the synthetic. Because of that, and because some synthetics state the won't bond if applied on top of any sort of waxes or polish oils, the generally accepted process is to apply the sealant first, wait 12 to 24 hours, then top with a carnaua. But again, you don't really have to do this, using one or the alone is perfectly fine.
As for Ultimate Quik Wax spray and D156, yep, basically the same stuff. If you use a lot, and it is great for applying while drying the car, then D156 is the cost effective way to go. And for a spray wax it's crazy durable. And it won't stain plastic trim (will usually actually make it look better, truth be told).
