Meguiar's 105/205 or their Mf cc/finishing polish?
Sully6541
So I'm a newbie that has been bit by the detailing bug. I just trying to get my wish list ready for when the warmer weather comes. I'm pretty sure I'm going with the GG6 and the Meguiar's MF pads. So my question as the subject states should I use the MF compound and polish or 105/205?
Thank you all in advance
Rather than using 105 cutting compound, you usually can remove all the swirls with Meguiar's No. 9 Swirl Remover, then finish with sealant and then wax.
Roger T
The dedicated MF system is foolproof and insanely easy to use to achieve amazing results. I would recommend D300 MF Correction Compound and M205 Polish.
Sent from my N9810 using AG Online
M105 is not for newbies
I agree as well.
I would recommend the megs microfiber cutting pad with D300 followed by M205 and a polishing foam pad. That would give a nice finish. You could also go with ultimate compound as that is user friendly with a foam cutting pad and follow that up with M205.
The Meguiar's 105 Compound takes time to learn how to use it.
How about using Meguiar's Ultimate Compound? Over the counter product.
Even with all my compound choices I still use the Ultimate Compound at times, it can do some serious paint corrections and is very user friendly.
Another great compound is the Wolfgang Über Compound, decent work time, very little dusting and won't gum up on you like the Meguiar's 105 Compound can do at times.
The Meguiar's 205 Ultra Fine Polish is my go to polish, long work time, no dusting and wipes off like a dream:)
The Griot's Garage Buffer is very good, I've done some paint corrections that were thrashed and the buffer never backed down until it died on me but Griot's gives us a lifetime warranty so I'm sending it back, I spoke with Griot's, they said for me to send it back and they'll send me a new one.
How bad is it really?
If you could post some photos there could be a more usable product recommendation for a compound.
It's possible you might not need a compound, instead just use M205 with a more aggressive pad then change pads for the finishing step.
But WG Uber Compound, Megs Ultimate Compound and M105 all would be good choices combined with the right pad choice depending.
They all can finish down well with the proper technique, LSP ready or very close to it depending.
Then follow up with M205 for the finishing step to really enhance the gloss using either a polishing or finishing pad depending.
D300 followed by D302 using MF pads. Easy and fast.
Awesome. Thank you everyone for the advise!
Mf pads on soft paints? I would love to know this also! I seems like IMO that it would leave marring or da haze?
Make it easy on your self get Menz FG400 very easy to work with and I get great results it and MF pads.
Did you use cutting or polishing MF pads with the FG400 on that black tundra? I have a black tundra I am doing at some point and planned to use FG400 on that.
+1
The MF system with D300 is hard to beat in both cutting & finishing ability. No other company can match that.
Visa versa, Meguiars pads paired with Menz polishes produce excellent results as well.
Cutting pad and I only did a 1 step Here is the finished pic for you. If you look at the thread for this truck I posted I used a yellow uber pad but I switched to a MF pad cause I got better results with it. I for got to post this in the thread.
Very nice for a one step:dblthumb2:
Sure saves time!
