Meguiar's M101 Foam Cut-Compound versus Swirls!
This Thursday night we'll be showing the correction power of M101 Foam Pad Polish on Jay's swirled-out 1999 Trans Am and everyone that attends will not only get a chance to test out the new Meguiar's M101 Foam Cut-Compound.... they'll also get a chance to try it with multiple tools and pads...
A detailer's dream come true!
Playing with all types of tools and pads with Meguiar's M101 Foam Pad Compound
From left to right...
Meguiar's G110v2 with Lake Country Yellow Heavy Cut Foam Pad
Makita BO6040 with Surbuf 6.6" pad
Flex 3401 with Lake Country Ultra-Microfiber Pad
Down in front...
Griot's Garage 3" Mini Polisher with Meguiar's 3" Microfiber Cutting Disc
Meguiar's G110v2 with Meguiar's 5" Microfiber Cutting Disc
To the right side...
DeWALT 849X Rotary Buffer aka Bumblebee
Flex PE14 Rotary Polisher
Cyclo Model 5 Pro Orbital Polisher
Here's our extreme makeover candidate, this car has been neglected and sitting outside in South Florida weather, uncovered, exposed to the intense sun and wet, rainy weather since 2009! That's almost 4 years of neglect and zero attention!
Sign-up - 1999 Trans Am Extreme Makeover!
Date: Thursday, November 8th, 2012
Time: 5:00pm
Jay's new classic...
This is my buddy Jay's recent purchase, it's a Anniversary Edition 1999 Trans Am with the 6-Speed Hurst Shifter.
He's ordered a new graphics kit so our job will be to remove the graphics, buff out the paint and the apply the new graphics.
The body and paint are all intact just dull and filled with water spots and swirls...
Swirl City!
The entire finish looks like the swirl shots taken in the sun below...
Close-up next to the hideaway headlight bucket -
Tip: Use a body line to help your camera lens to focus on the paint.
Get ready for some fun and feedback on the new Meguiar's M101 Foam Pad Compound...
:buffing:
Re: Meguiar's M101 Foam Pad Polish versus Swirls!
Mike-
Is this going to be a live webcast?
Just to note...
I did speak with Jason Rose about this project car and using the new M101 Foam Cut Compound and I asked for his recommendation and he recommended I use the M101 as it is formulated and intended to be used and that's with foam pads on rotary buffers.
So priority #1 will be to offer everyone that attends Thursday night's class a chance to use the system as it was designed to be used.
Since I know it's the nature of pro detailers and enthusiast detailers to like to experiment and push the envelope to the limit I do have all the above pictured tools and pads set-up and available for everyone to use.
:xyxthumbs:
Mike-
No...
I checked with Yancy a few weeks ago as to when his schedule would be freed up enough to hang out AFTER work all day and do a live broadcast and he said he would be ready for the extreme makeover on Tim's 1957.
If you click the link below you'll see I've stated the 1957 will be a live broadcast. It's in post #6 and I'll add the graphic today. So you might want to consider driving here Buddy and being a part of this M101 Project.
Thursday, November 15th
Tim's 1957 Chevy - Extreme Makeover
Here's what it really looks like, the paint is completely filled with scratches...
Click here to sign-up!
Tentatively, Yancy says he can be here to do a live broadcast.
Here's Yancy doing what he does best...
Here's Yancy's eyes...
:dblthumb2:
I am interested to see how the MF cutting disc on the DA works with the 101 versus the D300 compound.
Oh yeah...
Besides rotary buffers, check this out... plus of course I'll have the Porter Cable 7424XP, the Griot's Garage 6" DA Polisher and even an air powered 3M orbital sander hooked up for someone to play with.
M101 with Meguiar's G110v2
Meguiar's M101 with Flex 3401
Meguiar's M101 with Griot's Garage 3" Mini DA Polisher
Meguiar's M101 with Cyclo Polisher
Meguiar's M101 with Makita BO6040
Feel the power!
3M Random Orbital 6 Inch Air Sander 20325
:xyxthumbs:
Trying to get my body shop on the Meguiars line instead of the 3M line we are currently on.
What grit sanding marks can the 101 and a burgandy cutting pad eliminate Mike? 1200?
Autogeek will have M-101 in stock very soon. :dblthumb2:
So I gotta ask since Mike asked me the same question earlier in another thread....
With M105 do you need M101? I mean how much cut do you really need?!?!?!? Im the MAN
Nick are you guys getting the new Opt No rinse wash n wax soon??
I been waiting for all these new 2013 goodies that i saw in pics from sema!!!
The Optimum No Rinse Wash N Wax will be available the first week of December. :)
Ha ha...
That was just a hypothetical question.
My point was that M105 already cuts plenty fast for the majority of users especially people new to machine polishing in other words, Newbies and Enthusiast Detailers.
Remember, factory paint is thin, so always focus on the task at hand and AFTER you remove defects to your satisfaction, implement procedures that don't re-instill swirls and scratches so you don't have to repeat the correction process.
:dblthumb2:
Good luck with that...
What grit sanding marks can the 101 and a burgundy cutting pad eliminate Mike? 1200?
Probably but two things to keep in mind,
1. FULL SIZE Foam cutting pads on a Rotary Buffer generate a lot of heat fast. From what I know the M101 was originally intended for use for spot repair using smaller pads. At least I think I read something like this posted by Mike Stoops, I could be wrong, someone can check on that if it's important to them.
Spot repair with smaller pads = less heat
2. My personal practice and what I recommend to anyone else doing any dry sanding, wetsanding or dampsanding is to finish out with the highest grit possible to make the buffing process faster and so you don't generate as much heat.
Heating up a clear coat finish while compounding it is called destructive polishing. I have an article coming out on this...​
Also, keep in mind that 3M has recently introduced #5000 grit sanding/finishing discs and when you finish out with this high a level of a disc buffing out the sanding marks is a breeze with a compound and also very easy if using a medium cut polish.
I covered this here,
3M Trizact 6 Inch 3000 Grit Performance Sanding Disc 01459 - Singles
Video: Wow! 3M #5000 Grit Polishing I mean Sanding Discs!
3™ Trizact™ Foam Discs 5000 FAQs
New Toy - #5000 Grit Trizact Foam Finishing Discs
I personally would never stop at #1200 grit and instead would finish out with the highest quality sanding papers and discs I could obtain. It just makes good sense and is safer for the paint.
Of course Mike. I just want to have all my bases covered. Right now I am doing the cutting with 1500 and then following that with 3000 and it comes out great. I then follow that procedure with M105 on a yellow W8207 and it pulls out all the sanding marks on fresh paint.
I did a little side by side comparison between a W7207 and a W8207 with M105 and boy does that burgandy pad get the surface hot.
Is the T/A single stage?
OEM or repaint?
One day I'll make it to AGHQ...not in the cards in the foreseeable future.
OEM or repaint?
When you do VT let me know.......and if Mrs07 will let me go out and play,you can pick me up on the way!
OEM or repaint?
It's BC/CC. I have one in arctic white too, the paint is almost as hard as corvettes. Looks like oem paint to me too. Can't wait to see the turnaround!
Very non-aggressive combo for fresh paint, not like the old days...
I did a little side by side comparison between a W7207 and a W8207 with M105 and boy does that burgundy pad get the surface hot.
Exactly and that's why you have to be very careful if you're working with large foam cutting pads on rotary buffers with compounds, if you're not careful you'll heat the paint up and twist it.
I'll be keeping a very close on on everyone buffing on Jay's Trans Am...
:dblthumb2:
OEM or repaint?
Looked like the factory basecoat/clearcoat to me. Keep in mind the car was only here for minutes and while it was here my primary goal was to take advantage of the sun to document the true condition of the finish, not the originality or type of finish.
It did look like a basecoat/clearcoat finish by the appearance of the swirls. Remember, single stage paints oxidize readily while basecoat/clearcoat paints swirl readily, I cover this in my article here,
The practical differences between single stage paints and a clear coat paints
We'd love to have you anytime that it works for you in the future...
Thanks for the replies guys.
Thanks for all that you do to further educate us Mike
The reason for my question is that I'm under the impression that the 101 is modeled for the repaint industry.
I don't follow Megs so I guess that I'll follow the soon to be upcoming threads to get a better idea of the product.
Real talk: AGHQ is on my bucket list....lol
