Power Gloss, SIP, and 106FA, that should cover pretty much anything you encounter. I would make sure you have a few of the wool, orange, white, green and blue pads. If you are using a rotary I would not use the orange pad and use the wool and work with the other colored pads.
Both LOL correct me if wrong yellow wool pad for cutting with a rotary and white for polishing with a rotary ??DA only - PC? I'd get 4" orange for correction and white for polishing - maybe 5.5" with the white, and you can use blue or gray for final polishing if you want. I have tried SIP, IP, FFII and 203 - all met or exceeded my expectations.
purple foamed wool to start. Then go the the LC foam pads. Use the white/gray after the PFWWhich color wool pad would you use for that combo
