I almost exclusively use Menzerna FG400 and SF3800 (old name SF4500 and older name PO85RD) for everything. Depending on the pad, they have a tremendous range of types of paints it works very well on. For my Flex 3401, i have LC, B&S, and Meguiars MF pads. For my Rupes Bigfoot Nano, i use Rupes pads. I plan to eventually try cheap eBay Chinese made pads too. Menzerna has a super long work time which i prefer. I do fairly small sections (one door split into 4+ sections), 5-9 passes on each application, with about 5lbs of pressure
Have you ever had the 4500 dust up on you? How's your arm speed with it too?
Just curious how much you guys/gals are working the product.
Machines, speeds, passes, pressure, pads, etc.
Thanks!
Here is an article I wrote a while back on getting the most out of Menzerna polishes with FLEX machines.
http://www.autogeekonline.net/forum...rning-3401-menzerna-products-hybrid-pads.html
You might want to test the Menzerna with and without "pad conditioning" first...
IME Menzerna likes a nice clean and dry (not wet with water) pad
Arm speed medium to slow. If you noticed a trend with Menzerna, everything is slowed down just a bit. You're caressing and making love to the car rather than "wham bam thank you ma'am" with Meguiars 105/205.
Ive never had SF4500 or any Menzerna polish/compound dust up on me. As a matter of fact, it's generally known that Menzerna is on the oily side so it's pretty much impossible to dust if used properly. I always clean the pad with a stiff bristle brush after every panel. I've had FG400 gum up on me, but not dust.
I haven't been on the forum much lately but <<< thats SF4500 (now called SF3800, prior known as PO85RD) in the avatar as i'm priming the pad
I have been avoiding using the 4000 lately on finicky black black paints on high temps. Hard time removing the oily residue, prone to mf marring.
I really like the finishing, though
So the shine can be improved upon by following 3500 with 3800? Or do you think it would be a waste of product and time most of the time? I ordered FG400/SF3500 and SF3800. I'll experiment with everything.
