Here is my dilemma... I own a white 2013 VW GTI. There are some scratches in the clear that nothing would touch the last time I dedicated a good bit of time to polishing the car. I tried Lake Country Yellow cutting pads with Optimum's spray compound, 3M compound, and Chemical Guys V32. For giggles, I worked a test spot for nearly 20 minutes, and noticed no significant difference between it and the untouched area next to it. I even repeated the process on the front door, and noticed no significant difference when compared to the rear door.
The common consensus when asking others what to do is that I either need to switch to microfiber cutting pads OR or move to the Flex XC3401 if I want to stick with foam pads. It would appear that my VW has a super hard clear coat that makes it tough for the Porter Cable and foam pads to level out.
One of my friends even suggested that I keep the Porter Cable and just get a rotary to cut with. The only down side is if I maintain the car after correcting it with a rotary, I'll probably never need the rotary again.
Naturally, trying microfiber cutting pads next would be the simple solution. My only dilemma with doing so is if the scratches and minor etchings don't come out again, it will have been yet another waste of time, money, and effort.
I had my hands on a friend's Flex, and I hate to say it, but I like the ergonomics and layout of it way better than the Porter Cable. My dilemma here is do I really need to spend another $400 just to make use of the Lake Country foam pads that I have on hand and will it really be that much better than the Porter Cable 7424XP with microfiber cutting pads?
Lastly, I'm on the fence about a true rotary. While I have used them in the past, I have been known to let my mind drift every now and again while polishing my car versus paying complete attention to someone else's. Because of that reason, I'm hesitant to purchase a rotary for my own vehicle because I'm just a hobbyist detailer and do not do this for a living.
