AWE underdrive Pulley, AWE pulley-puller tool, OEM undersized belt (I assume it's undersized), GIAC handheld program-switcher, GIAC software code, a bunch of blow-pops, and my new BD toaster oven (required for the install) showed up! Big thanks to Todd @ AWE and Sean Doyle at TAG Motorsports. Great guys!
Can't believe AWE actually patterned the blow-pop into the foam. These guys are hilarious, and EVERYTHING (including the packaging) is TOP NOTCH!!!
As many of you know, our TVS1320 blowers utilize an interference/press fit for the pulley. Here's a picture "bakin" the AWE pulley in my new toaster oven (yes, I did buy it just for this). AWE recommends 375 F at 1 hour for the correct thermal expansion to take place. At 400 F, the coating (I'm guessing powder or E-coat) can be compromised. Again, take your time, enjoy the labor of love, wait for the pulley to heat correctly and thoroughly, and generally accept that your car is gonna have more power real soon...
The B8.5 doesn't have long bolts installed underneath the core support (at least I didn't care to look more than a few minutes for them). Regardless, AWE is kind enough to include long bolts in the kit so that you can remove the 16mm core support to frame-rail bolts, re-install the new AWE-supplied long bolts, and slide out the core support. THANK YOU (I was looking in my bolt bucket for long bolts before I realized AWE included them)!
B8.5s (and maybe the B8) use a new style of washer line connector. As it turns out, once disconnecting the headlight washers, the system can self-contain/close-loop the res. without draining all of the contents on the floor, all without using a CAP!!! This is awesome. After pulling core supports on Audis for the last 13 years, I can finally say that on this trip, I only lost about .2L of washer fluid on the floor this time while I "figured it out." Awesome....
A picture of the stock supercharger belt routing (could come in handy for a few)
Core-support pulled away from the frame
Cap removed from the stock charger pulley and stock belt removed
AWE puller-tool on the stock pulley. Make sure you use AMPLE amounts of anti-sieze on the jam-bolt. JAM_ON!
Stocker pulley removed!!!
Here's a quick shot of what the stock TVS1320 input shaft looks like, naked (oh my!) without any pulley.
AWE pulley installed (and capped) comparo photo with the stocker
I actually installed the pulley twice thinking it wasn't "bottomed out." However, this appears to be normal. Again, AWE pulley installed (and capped) comparo photo with the stocker being held in my hand.
New belt installed (make sure you get the routing correct, not real difficult).
How I left it for the night. I'll re-install the front bumper tomorrow, maybe install the summer wheels/tires, and possibly clay down, then final polish, and then wax/seal the car. Supposedly, there's a car show in the area on Saturday. With 41 F and rain/wintery "mix" in the forecast, I may just leave this thing sitting in the garage the next few days and drive my truck...
Test start, warm up, and a few revs! I'll Vag-Com out the bulb out errors tomorrow. ECS Luft-Tecnik cover is still off of the airbox (audible goodness, and I might actually leave it this way). Listen to that blower sing!
https://www.youtube.com/watch?v=gNZgw3hRJdc
Will probably talk to Lichty about possibly doing the GIAC V2 STGII reflash sometime early next week.
STAY TUNED!!!
-Dan Lensch
