frankprozzoly
- Mar 28, 2014
- 1,596
Now I'm thinking that a brake pad is loose. Is that possible? I'm noticing the sound is a little more pronounced when I brake
It could be a caliper bracket bolt. I had one that was a little loose on my 06 altima and a very distinct "clunk" would come from the front left wheel area. I first thought it was suspension, but after taking the wheel off an inspecting I saw one of the caliper bolts was almost completely undone and out of the threads completely. Tightened it back down and had no more clunking.
...That should be pretty easy to do...I do.
I was just gonna have a looksee
if it was something obvious
What kind of noise do you have? Is it a "pop" or a "clunk" when braking - or is it something that follows the rotation of the wheel?
My guess is the former, as this isn't super uncommon on a new vehicle. Since it's a new vehicle - make it the dealer's problem. Most likely there is nothing "loose" per se....
But something that just isn't torqued down enough. Common problems are sway bar links/mounts, strut mounts, rack bolts, ball joints, and subframe/cradle bolts.
On this type of noise, the fix is just usually going over everything with a burst via a 1/2" impact gun. Believe me, nobody at a dealer is getting out a torque wrench for this type of work.
Rarely is a part itself actually to blame, but it occasionally does happen.....
Lotsa times dudes would hear strut type noises on new cars and order front struts and mounts. Parts come in, and in the process of getting hung it's found a loose strut bolt is the real culprit. So, noise gets fixed, new parts get hung - everyone is happy.
