Mike@DedicatedPerfection
- Feb 26, 2011
- 12,365
My technique concerning the 3401, Menzerna products, and Hybrid pads
Hey fellow Geekaroonies, I recently wrote out my technique when using my favorite setup. Seeing a few recent threads concerning the use of the Flex or Menzerna products prompted me to bring this in to view of others. I have copied this from my word document and pasted it here.
If you would like my word document emailed to you so you have this on file for easy reference, just send me a PM and I will send it over.
My methods when using Menzerna products, Hybrid pads, driven by the Flex XC 3401 VRG
FG400 and cutting pad speed 3-4
S4000 and polishing pad speed 4-5
When starting with a fresh new pad regardless of color choice or Menzerna selection is to first prime the pad with one mist of a pad conditioner or equivalent and then 4-6 dime sized dots of product depending on the size of the pad and area to be worked.
With the pad primed and ready to work with I set the speed dial accordingly to my options above, gently pull the trigger enough to activate the machine (basically speed 1) and do one brisk full coverage section pass in the section that I am going to work to spread the product out with only the weight of the machine.
Once the product has been spread out I squeeze the trigger fully to operate the polisher at the selected speed on the dial and start my normal routine of compounding or polishing with moderate to heavy pressure depending on what’s needed.
I also like to work Menzerna products longer such as 6-8 passes instead of the normal 4-6. When I get to the last 2 passes I ease up and only use the weight of the machine to finish.
When I am finished with the section that was just worked there should only be a very thin and clear residue left to wipe up which is a breeze to remove.
After the section was compounded or polished my method to cleaning the pad “on the fly” is to brush the face of the pad with a pad brush or mf towel while the pad is at rest. I don’t hold the brush and spin the pad against it as I feel this accelerates the wear of the pad.
When I am ready for the next section to be polished I will simply add the dimed sized drops of product without the pad conditioner as the pad has been in use and is seasoned.
Doing it this way will get me through half of a hood, a fender, a door, or trunk lid depending on panel size. After I have completed polishing half of the hood or the fender with multiple section passes I will then clean my pad in a pad washer and spin them dry on my rotary and set it aside face down on a mf towel to dry and will grab a fresh dry pad and condition it for use for the next panel.
I rotate 2-3 pads this way of the same color per compounding or polishing step to allow the others to dry while each pad is in use. This way after each panel I always have a fresh clean pad to use.
Alas, questions, comments, critiques welcomed.
