judyb
- Jan 6, 2008
- 145
There does seem to be a good deal of confusion going on!!
Foam cleaners are the most effective and safest way of cleaning leather - they allow for dwell time which gives time for any dirt to be lifted from the leather they are also the most economical as they make your product go much further. Using a foam means that the dirt is encapsulated and taken away from the leather rather than just moving the dirt around which most liquid cleaners do. Using a liquid can potentially be risky as some, if allowed to run can etch the finish on the leather which can be difficult to fx.
Successful cleaning is all about understanding the problem and using the appropriate methods and cleaners.
Dye transfer is a process - just using a stronger cleaner can lead to problems so use the gentlest first moving to the strongest.
You can use a brush to clean with a foam but this is not used to scrub the dirt out it is used to agitate the foam so that it can do its job properly.
Using an APC can lead to issues with the finish as most contain chemicals that could damage the finish on the leather and because the dilution rate is left up to the operative it will not have been tested.
Water is good for leather and necessary to keep it in good condition.
Hope this helps
Judyb
Hope this helps
Judyb
