Thank You! Im using a GG6 should I be doing the above on about setting 3 or 3.5??
This paint must be soft to leave hazing from XMT360. Or maybe the cleaner/wax was over worked (dry buffed)? In any case if it is SS paint then the color will come off on the pad. I'd recommend hitting it with Meguiars #7with polishing pad or waxing pad which will rejuvinate the paint with oils. If that doesn't clear up the haze I like M205 and a white pad then maybe #7 and finally wax. In either case if it's SS getting oil back into the paint will help it.
Also I don't see the need to do a chemical wipe if you plan to polish. That alone could leave hazing. More over your planning on waxing vs sealing so just polish and wax.
Well I've done 2 white Tundras and 1 white pickup all with single stage paints. M205 on a white LC flat pad worked on them all, never had any hazing problems
Sent from my DROID RAZR using Tapatalk 2
