Don M
Active member
- Jan 8, 2010
- 2,254
- 14
I just bought the Paint Protect 365 at Walmart and I need some tips & tricks from anyone experienced in its use. I did a quick WW using D115 on my hood, roof and trunk lid so I could give the PP365 a quick test run before going to bed. I used a mf covered sponge applicator and applied several "dots" of product to the applicator, then basically wiped it on. I gave the three panels about 10 minutes, then started buffing with a clean mf cloth.
I had to buff the heck out of it because it was leaving shadows, clouds and 'smears' on the paint. I also discovered that I have to change buffing cloths fairly often as they seem to load up and not remove the PP365 as well (the hood was the worst).
Most recently, my car was polished w/Klasse AIO and had a coat of Ult Liquid Wax applied. Since then, it has seen several uses of UQD & UQW and now UWWA and D115. Should I polish the car with Ult Polish to get down to clean paint and start over, or am I good to go as is?
I'm pretty sure I put the PP365 on too thick and I'm going to work on applying it thinner. Right now I'm applying it by the half-panel ... half the hood then the other half, half the roof, etc. Is that too much? Should I work in smaller sections?
Right now, I'm waiting to see if the smears fade out, like many waxes do once they lay after a while. If it does, the probably 80% of my issues will be gone.
I would still like any opinions on my process and all suggestions are welcome.
