New 4" and 6" Backing Plates for Flex 3401
These are prototypes Eric Dunn sent me to test and evaluate, we'll be stocking these when the design is finalized and they go into production.
On the left is the 6" backing plate, center is the 4" backing plate and on the right is the interface plate that enables you to switch between either the 6" or the 4" backing plate.
Here's a view of the other side so you can see the ribs for strength, the plate itself is very rigid and this is part of the design that does away with the felt ring.
The protruding tabs lock into the slots on the interface plate and then both are bolted to the spindle.
Here's a shot showing size comparison between the new backing plates on the right and the existing backing plates on the left.
The stock backing plate that comes with the Flex 3401 measures 5 7/16"
The new 6" backing plate actually measures a little larger than 6" inches to full support the back of a 6.5" pad. This dimension is subject to change in the final production versions.
On the left hand side is the factory backing plate on a 6.5" foam pad and the new 6" backing plate on the exact same pad.
The picture is a little deceiving as the outer edge of the backing plate actually extends "almost" to the outer edge of the back of the pad. Again, this dimension is subject to change in the final version. Currently the diameter = 6 7/16"
Here's the 4 3/8" backing plate on a 5.5" foam pad...
The 4 3/8" backing plate is too large to use safely with a 4" spot repair pad
Here's the new 4" backing plate with a 4" pad
Ready for some testing...
We'll be trying these out on a 1986 Buick Regal that we're working on for our first "Autogeek's Car of the Week" project.
Autogeek's Car of the Week - 1986 Buick Regal T-Type Turbo
On Autogeek.net
FLEX XC3401 Changeable Backing Plate System
:xyxthumbs:
Woohoo!!! 4" BPs for the 3401!! Been waiting for this!
Any idea what the pricing will be for these? Can we buy the 4" and 6" BPs individually or will they be in a package?
Looks pretty slick. Looks like another purchase in my future.
Very cool Mike. I'm glad that there are finally more options for the flex
This is great news Mike and Thank you for posting some great photos of the new design . I remember last March during Detail Fest talking to Eric about some new backing plates for the 3401 . Only one concern I have if there is any failure of the 3401 while it's under warranty will Flex be able to tell that the original backing plate wasn't used .
I guess we will cross that bridge when we get there .
Aw man!!! Mike, I wished you had put "coming soon" in the title... I'm ready to buy :(
I wonder when they will do microfiber pads.
That is very clever. I wonder why they didn't come up with this a long time ago. It seems so simple.
Put me down for both plates and an extra center screw....just in case I lose one from changing plates.
Now I'm glad I never picked up the 4-3/8" backing plate... I really like the idea of these.
Tested out both the 6" Backing Plate and the 4" backing plate and both worked flawlessly.
The 4" backing plate with a 4" pad really works well for thin panels or hard to buff areas... very easy to control the 3401 with smaller pads like the 4" spot repair pads.
Testing out the new 4" backing plate for the Flex 3401 with a 4" Tangerine Hydro-Tech Spot Repair Pad
More pictures here...
Mike thanks for the comparison on these, I'll be looking for them when they come out, were you able to notice any reduction in heat being generated inside the steel case?
I wish these were for sale a couple of weeks ago, when i bought my new flex 3401. That I saved up for, cant afford it on a slaveway, no safeway salary and while going to college.
Awesome !!!!! Thanks for putting this together. I find myself using my Flex less because I can't switch BP's. Guess that is gonna change.
Not really.
I took the forward handle off and then simply bolted the plastic cover back onto the head of the unit because with the 4" pad on the tool I just felt the handle would get in the way of working mall areas which kind of defeats the purpose of the small footprint offered by the small pad.
I have a really cool car coming up for Autogeek' Car of the Week where we'll have a very good opportunity to buff with the Flex 3401 for extended periods of time as the car is HUGE!
