jamesalanb
- Mar 6, 2013
- 180
Good feedback Chris, I'll def take better note to that when I do the next car.
Yes this stuff smells straight up like ipa...
I wouldn't use PPE. It's got fillers and oils.
Thank you for that advisement, and caution. I probably would've checked before using, but none the less, happy to hear that straight up front.
That seems to leave me with CP Eraser, or an IPA Mix. Not sure how effective either will be, since the Kia has been treated to a large slew of various sealants over the past 5-6 months, like WGDGPS 3.0, Menzerna Powerlock, WGDGLS, UPGP, and lots of feedings of DG Aquawax, and Pinnacle Crystal Mist Spray.
Washing-Claying-Polishing should remove some, and not sure if Eraser will "erase" the rest?
Am having some regrets now, of perhaps not getting the Detailer's Paint Cleaner?
Mark
This was my first time using a WOWA or coating type product so over-application is very possible for me.I have a bottle of the Detailer's Paint Coating coming as well, but did not order the Paint Prep product. It should be here next week Wednesday.
I have both CarPro Eraser, and the Wolfgang Paint Cleansing Lotion, so I reckon I'll try these, and see what results I attain? Hoping all will work ok?
The Kia's paint is feeling a bit "bumpy" again, so it looks like I might be claying, and perhaps some polishing will probably be needed after.
I have a fresh bottle of Menz SF4500 on hand also, and been wanting to try that as well.
I've read the entire thread so far, and have been following how some users are saying it's taking more product than initially anticipated?
At this point I am unsure, if this is the case, or if it is being over-applied?
I'd assume you folks who have tried it so far do have past experience with other WOWA's and Coatings, that your findings aren't due to inexperience, and over-application?
I don't have any finger pocket applicators on hand, but do have some small yellow foam applicators, so I assume I'll be OK in this regard.
We have been getting rain virtually every day here, but when I can, I'll put the products I mention above to use, and add some further personal comments when I can.
Mark
This is interesting because PPE is supposed to clean the paint for applying wax or sealant. Isn't the fillers and oils going to hurt durability of whatever it's topped with, yet it's marketed as helping to improve durability?
The suggestion of using DP paint cleaner beforehand; does this also mean DP coating has less ability to bond to non-perfectly clean paint compared to other sealants or waxes?
6-8 for this small hood, each door was 4 or so, and they're small doors. for me, it flashed almost immediately after 1-2 "swipes" on a section, it doesn't drag or soak an applicator like we're used to wax doing. That's why I felt like I had to use so many sprays. I buffed after every section.
Mark
Nick, how many section passes do you need for the paint prep polish? How much pressure? Thanks.
Wolfgang Paintwork Polish Enhancer is designed to be used with waxes and sealants. Detailer's Coating Prep Polish is a much better choice for paint coatings.
It sounds like Detailer's Coating Prep Polish would be a better choice for waxes and sealants too? No fillers results in better bond right?
Do coatings like DP paint coating have more trouble bonding through polishing oil than a non-cleaner sealant or wax?
From what I gather, doing the Wolfgang Twins people go right to WGDGPS without needing to use a paint cleaner or IPA. However, it seems like you'd need to add a step of using the DP prep polish after the polishing steps or the coating won't bond as well as the sealant would.
