bmwstephen
- Dec 27, 2012
- 72
bump! any feedback on using this on older SS paint finishes? Most of these results or feedback tend to be on cars with b/c finishes
Nice to find a thread talking about Dr. Color Chip. I have been using this for the last 8 months and have problems with it like some have faced. After seeing some of the guys state that it has to set longer I will have to do this.
I was doing just as instructed and also had a buddy do the same thing. We were baffled at why the SealAct was taking the paint out of the chip. I have chips on the H2 I received yesterday afternoon and it looks like I will have to apply this after polishing and just let it sit for much longer than we were doing before.
Would anyone see an issue with polishing all the painted chips to even things out. I was thinking a finishing polish with a velvet pad (used for orange peel.)
been going through this thread....just used Dr CC for the first time on monday for a very tiny chip on my car. Color matches and i've gone through about 3 coats over the last 4 days. and still can't seem to get it level. Its tough to notice due to the size and its now filled in with color....but what I'm reading here...i guess that's what to expect from Dr CC....would there be any value in trying to do more coats this weekend after a wash? is it ok to wait days in between coats....? it seems to pass the 3 ft test now...its just that i kinda know where it is..so it still bothers me....
I don't see it being a problem waiting that long in between coats.
Provided a couple things.
1, if you've applied any protectants to the paint, you should probably wipe the area with a mild IPA solution or a prep solvent first.
2, that you have left any excess paint outside the chip area.
It's probably common that touch up paints can shrink a little bit, so I say no harm, no foul by applying additional coats to produce a level touch up repair.
As you are getting to the finish with the use of the Sealact Solution, this is where patience, and finesse come into play.
I've seen and have had this happen with the Langka Chip Repair System in that you're getting closer, and closer, and the paint blob is leveling, then, poof, one or two swipes too many and you've now just about totally removed your touch up paint from the chip.
Now you're back at square 1 again
Now with the Dr. CC system, the paint dries quite quickly, but with the Langka, this system is relying on factory, or other touch up paints like Duplicolor, which can take forever and a day to dry. Was a system I basically shelved, who wants to wait hours-days to complete a touch up?
With the Langka System, I thought it was a total PITA, to have this happen, and then again try with such a long drawn out repair process. (What I did find the Langka Leveling Solution quite good for though, is removing past fubarred factory paint touch up jobs, then coming along with the Dr. CC after)
Plus with factory touch up type paints, applying to vertical panels, and if not possessing the finesse of a Michaelangelo, you can quite easily create sags with over-application.
Good lighting, and getting real close to the repair are definite aids.
Be comfortable. On many of the vertical panels, I used my nice little roll around stool to sit on, and had a 500W Halogen Lamp on stand a few feet on an angle away from where I was working
What do you think about leveling the dr cc paint with a credit card perhaps wrapped in the rubber glove to get it level?
You mean when first applying, then smearing across a chip?
I tried it on my Kia's hood, as this 15 year old hood looks like somebody took a sandblaster to it.
In that scenario what I found was a hell of a lot of excessive waste of paint. being spread where it had no benefit at all.
Thus I concentrated on doing smaller sections of the hood, breaking it up, 15x15 perhaps. Appy, then go to work with the Sealact Solution wiping down those sections initially, then better concentrating on individual chips to finesse.
If you're saying like the Langka Process, to then level with the paper towel like material to level, wrapped around a credit card like Langka, no, I didn't find a need to do that at all.
That as for leveling the blobs and excess paint applied, I found Dr CC relatively very easy to work with, just with supplied white rag, and the Sealact.
