Mike@DedicatedPerfection
- Feb 26, 2011
- 12,365
Sounds good Bill. Looking forward to seeing pics.
Results are amazing but I have a couple of questions:
1.) Is this a normal type of dusting for Meg's UC?
2.) Can you still do the cleaning pads on the fly with the Flex? how often?
3.) Should the LC Flat pads be getting warm while polishing? Does this mean I am putting too much pressure?
4.) Is it also normal for the aluminum head on the Flex to get very warm/hot during normal operation?
Sorry for all the questions. I had not had any of these issues with my DA polisher. I am not sure if all this is normal, part of the learning curve or I am doing something wrong.
Please provide a little feedback. I will upload photos of results shortly.Feed back please
I can't speak for uc as I haven't used it, but chances are you may be using too much product if you're getting really bad dusting. Play with the amount. Of product you use and you'll find what the right amount will be, that comes with experience.
With the flex, to clean the pad, you'll need a pad cleaning brush. Because of the forced rotation, you can't hold a towel over the pad while its spinning like you can with a da and remove the product. Instead, just turn the machine on and let a pad cleaning brush glide over the surface of the pad a couple times. You'll see the spent product dust off the pad. I like to do this after every section just to ensure a clean working pad.
Depending on the amount of correcting, the pad will get a little warm due to the pressure you're exerting on it. However, you shouldn't be throwing all your body weight on it, just a good firm pressure on the initial 2-3 passes for correction. Again, something you'll get the hang of the more you do it.
Yes, the head on the flex is notorious for getting red hot while operating, especially after hours of correction, so watch your hands!
Hope this helps
I followed instructions and spray the pad one time about 6" away with the pad conditioner. Apply (4) dime size spots of UC, polish a 24" x 24" area,
Hi Bill,
I explain all of this with "pictures" in my two articles here,
How to use Image Tags to insert a photo
How to insert an image from your photo gallery into your message
Once you do this a couple of times it all makes sense. Keep in mind, at one point in time I didn't know how to do all of this, I had to teach myself as no one wrote any articles for me...
:xyxthumbs:
Mike,
Thanks for the links, I was looking for them last night, I guess I was so tired and a bit frustrated, I was not able to find them right away. Thought I was doing ti the right way, but we all know how that goes at times.
Appreciate the help.
Bill
When starting out, it's easy to learn and get your technique down by working smaller areas. Every set of directions I've ever read for any tool since I've been alive always tells people to work a 2 foot by 2 foot area and that's actually a pretty big area to work especially when you're brand new to a tool.
The larger the area, the better the chance the product you're working will flash evaporate making the product more difficult to work with and causing a dusting and even gumming-up issue.
Work a smaller area and you keep your product more liquid on the surface and everything is a lot easier.
Heck, all the Porter Cable, Meguiar's, Griot's garage DA Polisher instructions I've always read tell people to work a two foot x two foot area and that's HUGE for these types of tools, that's why I've always typed and taught smaller areas. It's really just common sense.
See above... work a smaller section.
My article and technique on "Cleaning your pad on the fly", doesn't really work with the Flex like it works with a PC as the pad will grab the towel and rip it from your had.
Your picture of your pad in your gallery, this one,
You would clean that pad with a Nylon Bristle brush like a pad conditioning brush, also like I show in my how-to book the same way you see me using a pad conditioning brush on this Megs MF Pad. Keep things simple...
As for how often do you clean your pad? Recently this question was posted to our Facebook page for this video,
How to remove shallow RIDS and how to machine apply both a paint sealant and a finishing wax - YouTube
Here's the question...
how often do you typically do the 'on the fly' pad clean?
Here was my answer....
Common question. In a PERFECT world you clean your pad on the fly after each section you buff. By doing this you remove both spent product and removed paint. If you don’t clean your pad after buffing a section then you’re adding fresh product to a dirty pad and buffing the next section with all this gunk. In the REAL world, I clean my pad every other section. –Mike Phillips
All pads will get warm and even hot from "pressure over time". It's caused by friction from the pad against the surface of the paint and sometimes from the motor transferring heat down to the pad via the drive spindle, although I think this is mostly related to PC 'style' tools.
If you're working neglected paint really hard from lots of pressure and high speeds, yes you will get your pads hot and this will wear them out faster. Like the saying goes...
More pads is better...
Yes, that's why there's a forward handle and a rear grip on the body of the tool.
It's all perfectly normal and this is what this forum is all about... helping people that have purchased products from the AG store, (and really anywhere), learn how to get pro results.
:xyxthumbs:
Congrats on new Flex , did you prime the pad before you start application ! I don t see it much on pics .
Mike,
Thanks again for the detailed instructions. I have a copy of your book and had it by my side. I was reading and re-reading, but it does not explain a about the flex.
I am assuming due to the power and forced rotation that it would be treated like you would a rotary and part of the reason why I purchased this machine. I did also order a pad brush, so I have been using that as well, I just was not sure about technique, which you guys have been explaining. I just get a little confused as I am sure we all do just starting out, I have a lot more to learn and appreciate all the positive feedback..
Without this forum and you guys helping, guiding and willingness to spend time answering questions the learning curve for anything would be greatly increased and possibly even damage to customers cars. For this also I thank you and call those who participate.
I will continue to finish up the detail, and will post pictures along the way.
Thanks again to all..
Bill
I did, but not in the pictures, sorry about that. I tried priming the pad as Mike had in is book, that did not seem to work well with the Meg's UC on the Flex, worked great with DA. I did do one area with M105, priming like that was key, again it worked great.
Pictures show more of priming with the pad conditioner, I wanted to see if that was better. What I did leave out and I should have stated was everything else I tried. I have 3 pads that I was rotating, I am just trying to figure out the best process and realize that different products require different process. Meg's for some compounds have a shorter working time than some Menzerna.
Thanks for the comment, sometimes we forget basics and many of you guys have been doing this way longer than I.
I understand completely, I work with many very complex machines and you have to make it simple for everyone to understand, this you have done very well..The first edition was targeted at the Porter Cable "style" tools only as this is the first tool most people purchase when they move from working by hand to working by machine.
It was TOO complex try to write a how-to book that would actually do justice to showing how to use multiple "types" of tools PLUS have ALL the information in the book that's I included in the first edition.
Will have to add to my wish list now, you guys really know how to get us hooked, :joking:, line many others this is a way to relieve stress and put some shine on the world.The NEW, second edition does include updated information and chapters on these tools,
- Rotary Buffers
- Cyclo Polishers
- Flex 3401 Polishers
:iagree:, I have read a couple and I was hesitant to order yours at first, I am so glad I did and for anyone getting into this as a profession and or hobby, these are a must read, IMHO!The only way a person would understand this is if,A: They actually know how to use all the tools.Most all the how-to books on car detailing I've read in my life don't have any valuable information on how to actually use tools.
B: They tried to write a book on how to use all the tools.
Mike, I would love to and plan too. My parents live near Ocala, about 3 hours away. I look at the dates and if I can get out of work might plan on dropping the wife and kids off and continuing on to Stuart for a couple of days. Price is well worth it. One day, I will be there...Well you're doing fine. I know not everyone can attend one of my detailing boot camp classes but in these classes the learning curve is completely flattened out because I stand right in front of you and show you how to do pretty much everything with all the various tools.
I just want to add one more comment, for me at the end of a very hard and bad day. I sit down and read through the posts here and in a very short period of time my attitude changes and it also helps to relieve my stress. Yes, these guys here are extremely high caliber, heck look at the work they do, :dblthumb2: and the dream cars.Just to add... we do have a great forum and the reason it's great is because it attracts a very high caliber group of people that are willing to help with good, real-world information.
We always learn mate . I ll need that lovely book from Mike one day . Love readings anyways .
Yes, you got that right. I think I have gone through it twice, I am not starting to tab and highlight areas that I need to work on and remember. Best part is that I am a very hands on type of guy, the way it is written even if you have no understanding of detailing you will get it. As my old soccer coach used to tell us it is the basics, we all tend to over complicate things. The book helps to remind me of this also.
