2old2change
- Jan 3, 2007
- 1,269
So if the vehicle has a lot of surface contaminates and all 4 sides of the towel get's completely covered, do you just rinse it off and continue use? Basically to the effect of "kneading the clay"?
The rubber type surface is only on one side of the towel which does give you four seperate sides when folded. After using my towel on about six different cars I have not yet seen a need to clean off the towel between panels. I have kept it wet with lube that not only acts as a lube but kind of flushes off contaminents as you go.
