Rsurfer
- Jan 26, 2007
- 14,161
- 26
Agreed, or move up to 3000 for final sanding. Less buffing.:buffing:You need to use the wool pad to remove the scratches.
I also try wet sand, I went from 1200 grit to 2000 grit, after compound a few times and polish, I still see wet sand scratches.
I used orange pad at 1500 rpm and white foam pad at 1200 rpm. do I need a more cutting power foam pad? I need more practice.
Do you have 2500 and 3000 grit? Although wool and compound should have taken out the 2000 like butter. You will have miro marring and need to finish down with a foam pad. Not too pleased that you are using Turtle wax compound.
You are either going to have to go over it with finer wet sanding paper or go back over it with your compound and wool pad to remove the sanding scratches.
so tomorrow I should go 1200 1500 2000 2500 3000?
the wool pad, is it the yellow one or the white one? cause I used the yellow one, the yellow one feels like cotten candy and the white one feels like a mob.
The White foam pad I was cleaning it with the Duo-spur pad cleaning tool. I plalce the plate side of the tool on the pad and it did that. I guess I learn my lesson.
I did use my finger tips on wet sanding, AG forgot to sent the sand pad, but it's on it's way.
