Noob at wet sanding
Mike..that looks like what I'm going to do :props:
Thanks for chiming in guys
I'll keep you updated next week
The only thing that bothers me is the size of the Meg block that comes with the sand paper
With such a small area between the chips...that block looks like it will make a large area to sand out..or mess up...O MY
Any tips on how to keep the sanding at a minimum?
or just go with the block for uniformity...
Cut backing plate to size for the job.
This is also an option, the Meguiar's #7200 backing pad is easy enough to cut with a pair of sissors.
Then figure out a way to hold it and the sandpaper together while you sand. You can cut a strip of sandpaper in a way that it will fold over the small block you cut our of the backing pad.
:dblthumb2:
:dblthumb2:
noted and thxs
