The only thing that bothers me is the size of the Meg block that comes with the sand paper
With such a small area between the chips...that block looks like it will make a large area to sand out..or mess up...O MY
Any tips on how to keep the sanding at a minimum?
or just go with the block for uniformity...
Cut backing plate to size for the job.
This is also an option, the Meguiar's #7200 backing pad is easy enough to cut with a pair of sissors.
Then figure out a way to hold it and the sandpaper together while you sand. You can cut a strip of sandpaper in a way that it will fold over the small block you cut our of the backing pad.
:dblthumb2:
