You did a
"Test Spot" first right?
That is you haven't buffed out the entire car only to find out that you're not getting the results you wanted?
A test spot proves your system so you don't waste your time. Make sure your "system" works to one small area before going over the entire car.
So would a yellow pad and the Menzerna polish touch the scratches or is it simply too much for a DA to take out.
There are swirls and scratches and then there are
RIDS
Don't try to remove the RIDS. Read this,
RIDS - The Definition of RIDS and the story behind the term...
And this,
Tracers Tracers - RIDS - Pigtails - Cobweb Swirls - Rotary Buffer Swirls - Holograms - Water Spots - Bird Drooping Etchings - Micro-Marring
If you've removed the majority of the shallow swirls and all that are left are the RIDS then you might want to learn to live with them as removing more and more clear coat n order to remove deeper scratches also means removing more UV protection.
If the paint is truly thrashed then you might want to keep that in context as you make your decision.
I think the last picture was 3 passes with the orange pad and M105, and it didn't seem as if I had a shot at getting them out.
Again, determine if these are RIDS or not, if you successfully remove all the shallow swirls so now the paint looks decent except for the RIDS then without getting more aggressive, either with pad, product or switching to a rotary buffer, you may have come to a point where you want to stop.
See this article...
"Taking your car's paint to it's maximum potential"
Sorry about the pictures. Guess my browser automatically resized them when I posted so I didn't notice.
I tend to click away pretty quickly from threads when I have to horizontal scroll, a person can't see the what's going on when a picture is
4000 pixels wide and 3000 pixels tall, which is the dimension of your first picture.
since this morning I cropped and resized these pictures and then buffed out a Mustang... it's not that hard to do and Easy Thumbnails is free and works great.
Stuart Grill and Ale House Car Show
800 pixels wide on any monitor...
Easy Thumbnails Website
Screenshot of the Easy Thumbnails Website
Anyway I have been using the PC for a couple of months now. I assume it's the 2nd Gen since I ordered it brand new not long ago. I split the fender into 3 sections so it was a small section I was working on. I have watched all the videos as well!
Get yourself some 5.5" orange foam cutting pads and work a section about 12" to 14" square for at least 8 section passes. Place a tape line on the paint and only work on one side of the tape so you can clearly see if you're making progress.
800 pixels wide
If a DA Polisher will remove a little paint then it's just a matter of investing enough time working small sections removing little bits of paint to eventually remove the defects you're going after.
A rotary buffer would do the job a lot faster with a wool pad or like Dana said, get some Surbuf Microfiber pads, get them from the local store or support the company that offers support via their forum...
I'm a big fan of Win/Win deals... it's good when everyone wins...
rops:
