WRAPT C5Z06
- Nov 12, 2009
- 12,615
With wheel cleaners like Sonax/Griot's are they actually removing iron like IronX, or is the color change for the cool factor? Does P21S Gel clean wheels the same way, just not change color?
Obviously, yes, but that wasn't the point of my thread. I don't know if the color change is showing that iron is being removed, or it's just removing brake dust and looks cool. Is brake dust considered iron?? :dunno:This may be under-thinking things, but if iron was there when you started, and gone when you are done wouldn't it be removed?
Oh ok, I see. In that case I don't know.Obviously, yes, but that wasn't the point of my thread. I don't know if the color change is showing that iron is being removed, or it's just removing brake dust and looks cool. Is brake dust considered iron?? :dunno:
Basically, let's take P21S wheel Gel, does it remove Iron like Griot's/Sonax, or is that an added benefit of the wheel cleaners that change color?
Using the GG HD wheel cleaner for the first time the other day, the only areas where the cleaner changed color was when it hit the rotors. Based on that I'm assuming the wheel surfaces didn't have much, if any, iron built up on them (ceramic pads?) and that the color change isn't just a gimmick.
Basically, let's take P21S wheel Gel, does it remove iron like Griot's/Sonax, or is that an added benefit of the wheel cleaners that change color?
Let me answer your question (I think) with another question-Does the Finish Kare Step 2 iron remover change colors when it comes into contact with iron? I don't know. Griot's and Sonax may just make their product change colors, since we seeing is believing. It makes us feel better to see a change of some sort to know if a product is doing what it says or not.
Perfect answers, thanks!Yeah, it's not a gimmick, but I used it (Sonax FE) on two cars and it didn't work any better than any other pH neutral cleaner (P21S, original Griot's) and it didn't change color either, I'm presuming because of ceramic pads. If you've got conventional semi-metallic pad material (AFAIK almost everything today is ceramic, but what do I know) maybe it's a better match.
The content of brake dust depends on the pad material, and traditional semi-mets certainly have some ferrous materials in them, and rotors are, with some high end exceptions, iron, and they do wear down some. I take the mfrs. at their word that the Griot's, IronX, and Sonax FE have a chemical in them which does "dissolve" iron and changes color as a result (I think when the Sonax first came out I read somewhere what the chemical is).
FK Step 2, like Valugard step B, are acids which dissolve the iron (and no, they don't change color). As I noted above, these new products use a pH-neutral chemical to dissolve the iron (as opposed to the acids which are low pH).
I put in a call to Griots and talked to a customer service rep(not sure how much he knew), but he said the changing color is just showing the wheel cleaner is working, not removing iron.the description just says for Griots HD that "it changes color as it releases brake dust and greasy grime from the wheels". it says "it turns red as it encounters soil". so i'm thinking its just a change to let you know its working. and maybe you have a wheel thats not really dirty this would definitely show you where the dirt is
remember going to the dentist as a kid they say go brush your teeth and then give you that little tablet that made your teeth turn red where you didn't brush so well i think its kind of like that.![]()
So, for all we know, it could be changing colors by being exposed to oxygen, since the CS didn't go into what it's working on.I put in a call to Griots and talked to a customer service rep(not sure how much he knew), but he said the changing color is just showing the wheel cleaner is working, not removing iron.
Even if it's only a film of iron dust, I can't believe that anything but acid (and I mean acid, not just vinegar) is going to dissolve it. Like any other dirt, it just needs to be loosened from the surface with some or other detergent ingredients.I take the mfrs. at their word that the Griot's, IronX, and Sonax FE have a chemical in them which does "dissolve" iron and changes color as a result (I think when the Sonax first came out I read somewhere what the chemical is).
