Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 7
- Thread starter
- #81
For horizontal panels, one could put drops of Z1 onto the surface of the vehicle. Or is that a bad practice?
I too, had some product drop to the ground.
Nothing wrong with that.
Here's the Finger Painting Technique
You can use this for horizontal panels, vertical panels and like you see in the picture, tight areas or thin panels.
The BIG PICTURE is to spread the product and thus the abrasive technology plus the lubrication (whatever it is), onto the area you want to buff.
When I was doing the vertical panels on the truck sometimes I put product on the face of the pad and then QUICKLY placed the pad against the panel and sometimes I placed the product on the face of the pad and then used my my 4 fingers to scoop it up and then press it against a section of paint and then spread it around. After I was happy with how I had the product spread around if there was any leftover product, for example on the sides of my fingers, then I would scrape it onto the pad.
The start buffing.
Down and dirty detailing
