Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 8
- Thread starter
- #41
2018 Tesla Model 3 Long Range Dark Metallic Silver
Mike, is Z1 compatible with the Uro Fiber 50/50 pads?
With what was said above...Go foam.
Me---I'll start at middle with polishing pads.
Or go lighter--white soft pads.
No need for cutting or hard pads since Tundra is on the newish side.
Tom
So I could use this product and then top with the Pinnacle Black Label Diamond Ceramic Coating Pro?
How long do you think the coating would last?
The description of the Z1 says a year or more with the proper care.
Perhaps topping with an accommodating 1 year coating would be best?
Maybe - depends on if the paint is hard or soft.
Fibers are abrasives and on soft and medium paint the fibers themselves, regardless of the product will lead to micro-marring of the paint.
You rarely see me use micro-fiber pads. One reason is due to the micro-marring problem.
Fibers are a form of abrasive - Foam Pads vs Microfiber Pads by Mike Phillips
And yes, on the proper paint hardness.
Just to add my 2 cents, any coating that would normally last over a year for you on bare paint, should in theory last the same or more on Z1. In other words, Z1 isn’t going to dissolve underneath in a year or less, taking your coating with it and wasting time of your multi-year coating.So I could use this product and then top with the Pinnacle Black Label Diamond Ceramic Coating Pro?
The description of the Z1 says a year or more with the proper care. Perhaps topping with an accommodating 1 year coating would be best?
The above is going deep. But it's only deep for people that can and will READ. And of course, after reading, thinking about these deep things.
:laughing:
Any experiences on a totally neglected surface to bring it back to decent life with only one step? There are, I’ve read some.
I am working on a horse trailer this week. It’s 17 years old and has never been detailed (polished or waxed), and has rarely been washed.
Being that it’s white, my before and after photos won’t translate that well. There is plenty of oxidation and some swirling on it. I have a fresh tube of Z1 that I can will try out.
But my fair warning, as stated above... It’s white!
[/IMG]
