Oakes
- Dec 21, 2010
- 225
This 2004 Rally Red Evo VIII was a successful revival, from a very near critical condition as you will clearly be able to see for yourselves. When I first saw the car in it's pink very faded state, I almost feared we were witnessing failure, but I didn't give up on it then and there. After performing a quick test panel on the seemingly most deteriorated part of the car and seeing hope, it was deemed recoverable.
Over 3 days, and many many pads and polish later - due to the rally red Evo VIIIs being SS paint - the final result was more than rewarding. More time being spent on the rear quarter panels as they were not properly refinished after being resprayed, so we wet sanded them smooth and re polished them. However, this particular car wasn't completely revived yet, as we kind of went reverse on the process....It's awaiting a heart transplant for it's blown motor, meaning we performed the cosmetic surgery before it was able to walk again. I personally would want to revive looking good again and ready to go, but that's just me!
Hope you all don't mind the medical references, this particular Evo belongs to a Med Student, and just continuing with the theme!
The Products used throughout the process:
CG CitrusWash
P21S TAW
Sonax Green Clay
CG Clay Lube
Meguiars 105 - Purple Foam Wool
Menzerna SIP - Yellow Foam
Menzerna 106FA - Green Foam
P21S Paintworks Cleanser
Blackfire Wet Diamond Paint Sealant
Wolfgang Fuzion Wax
2000 grit - headlights
1500-2000-3000 grit - Rear quarter panels
Diablo Wheel Gel
Meguiars Wheel Brightener
Rejex Sealant on wheels
Trauma Pictures: You can just see there is no gloss to be found on this car as we arrived to it.
5.
So we prepped it fully, two full degreasing washes and clay, completely dried it, all edges and such. Corrected the wing then removed it, tape up the car and the following pics are post prep. Can really see what we were working with now, just look in the light reflections on the paint, or lack of so to speak, to really get an idea of how dull it was.
10.
15.
The following pictures are mix of 50/50 and before/after shots to show the difference as we worked through the car, they really speak for themselves.
Fender 50/50
We didn't just get rid of the dullness, all defects were removed on the car, like here on the quarter panel
Hood 50/50
20.
A-Pillar 50/50
Trunk 50/50
Before/After shots of the Hood. Shot in the same lighting conditions, no flash or enhancement made to any of these pictures
25.
Before/After of Passenger side doors
Headlight Before/After
30.
CG CitrusWash
P21S TAW
Sonax Green Clay
CG Clay Lube
Wolfgang Fuzion Wax
Diablo Wheel Gel
5.
10.
15.
Fender 50/50
Hood 50/50
20.
A-Pillar 50/50
Trunk 50/50
25.
30.
