On the Fly Pad Cleaning
I just went out and shot a video for you. I wasn't actually polishing so the pad was clean/dry but you should be able to get the idea. Also I forgot to do it for the video, but I'll spray some pad lube to help loosen the spent product. After running the polisher with two fingers and a MF, squeezing out excess lube and polish then re-running two fingers over the surface, the pad face should look relatively clean (depending on the product used). IMO, do this after every couple sections.
[ame=http://www.youtube.com/watch?v=M24NiGvBRgQ]YouTube - Pad cleaning "On the Fly" w/ Flex 3401[/video]
I just use compressed air, when I'm detailing, and they get cleaned at after use.
LOL A4 I use the same TV tray as my polishing table :)
SWEET! Thanks bro, :xyxthumbs:much appreciated
I'll have to try that, you have a specific method to share? Just spray the pad with compressed air?
HA! Yeah compact and convenient. It's probably pretty common, like that hydraulic rolling stool. :xyxthumbs:
No prob! I forgot to mention the speed, it was at 1, I like to clean OTF slowww... careful with the MF wrapped around your fingers/wrist...
Couldn't we use the Bucket Pad Washer and then just alternate between 2 Pads?
One Pad in use, while the other one dries in the Sun ?
So long as you're not using the Hydro pads! They can not be used moist and drying time needs to be calculated in days, not hours.
[URL="http://www.youtube.com/watch?v=M24NiGvBRgQ] - Pad cleaning "On the Fly" w/ Flex 3401[/URL]
Thank you very much for sharing...I was asking for a On the fly cleaning video a lot of time ago because I was not getting the picture of how was the method..again, Thanks!!!!! :dblthumb2:
Hey A4, I just wanted to say THANK YOU again. I have been using your two finger technique for the last couple days and it works like a charm! Especially wrapping the towel around your wrist first. Good stuff. I also let the brush run over the pad to open up the foam again.
Great stuff.:dblthumb2:
I'm glad I could help! I struggled to figure out the "On the fly" technique Mike shows for PC type polishers, until I realized it won't work with the Flex. :doh: I'm sure I got the idea from someone else here... don't remember who I should credit. So, when do we get some pics of your work? :D
I shot another video of cleaning on the fly and figured I'd post it here. This time it's actually in the process of polishing. Here I'm using Menzerna Power Gloss with a Yellow LC pad. I love how well Menz is cleaned on the fly, but I don't have much in similar polishes to compare it to.
[ame=http://www.youtube.com/watch?v=RjLl2HP13Jk]YouTube - Pad cleaning "On the Fly", black single stage paint[/video]
