Optimum Compound II vs M105?
ski2
Has anyone used both Optimum Compound II and M105? How do they compare in cutting ability??
M105 cuts faster.
Optimum Compound II and Hyper-Compound are both wetter products and have longer buffing cycles and easier wipe-off with little to no dusting issues but M105 does cut faster.
Thanks Mike!! Is the faster cut significant?? Twice as fast, three times as fast ???
Mike, I have gone by your suggestion in the book for doing 5-6 sections passes. Since you say that OCII has a longer work time, should I do more passes?
In my experience with OCII and M105, M105 definitely cut more than OCII with the same number of passes.
I don't know if it's drastic as cutting twice as fast, it just cuts faster.
Sure, if your test spot shows you need a certain amount of passes to remove the defects to your satisfaction and you're not buffing to a dry buff then continue making passes.
Wet Buffing Technique
Wet film behind your path-of-travel
:xyxthumbs:
Thanks for the link!! Great review and comparison--really answers the question in no uncertain terms!!!!
No problem brother, it's kinda old now and honestly thinking back I wish I would've named the title something else so the search function would help people find the info if needed.
I agree, thanks for posting the link John, first I'd seen your review. Nicely done and worth the read for everyone interested in Optimum compounds and polishes.
:xyxthumbs:
Thanks Mike! And if you'd like to change the title to something else so it's easier to find the info please feel free, I trust your judgement either way :)
When using Optimum Compound II do you use the Kevin Brown Method or just do a normal 3 or 4 dots to prime then a couple more each additional section??
