Optimum Final Polish?
WRAPT C5Z06
Anyone use this stuff? Does it use diminishing abrasives? What does it compare to in terms of aggressiveness?
I use it quite a bit and find it very similar to 3M Ultrafina. Has almost no cut, a good working time, no dusting, and leaves an outstanding finish.
Can Ultrafina be used with a Flex 3401? If so, what would be the best pad choice?
I'll throw my .02 in here .........
use with a red or black pad. Yes, this polish can be used with a Flex.
It has enough cut to remove 2500 grit sanding marks so it's very fine .......
I've used Ultrafina, Optimum Finish, and PO85RD with the Flex 3401 without issue. I start at speed 6 and make 2-3 section passes, then continue on speed 5 with minimal pressure and work the hell out of it (applies to all polishes mentioned).
