Optimum MF pads are here!
I too wonder how they will work with soft paint, or a car that has been repainted. Do you think that this is the direction the industry is going? Will anyone be using foam pads years from now?
Megs tested their pad for over 4 years and spent countless hours researching, tweaking etc and then it gets tweaked a lil and copied ... I wonder how much testing has been done on this pad...?
4 years of testing didn't seem to do them much good, based on the number of their blown pads you see here and on other forums.
the opt pads can be used on a rotary so the must be stuck on there real good...
I really don't see how this is pertinent in any way. If a certain product works, who cares? Use it, enjoy it, move on. :props:
They were saying that the Optimum sprayable products are what's recommended for these.
I have Hyper compound with new improved nozzle. It is still on the back shelf. The weak link in this new product may be the need for their spray products unless they make substantial improvement in sprayability..
The NEW NEW spray compound and polish are supposed to only need regular spray heads. I would assume the spray pattern is better.
