Optimum Opti-Coating - Durability Test Review!!!
David Fermani
The purpose of this test is to document the durability and effectiveness of Optimum Opti-Coat. Unlike mainstream polymer paint sealants & waxes, this coating is not offered to the general public and is only sold to licensed and insured professional detailers. After hearing several people raving about the results of this new product I reached out to Dr. Ghodoussi @ Optimum to discuss its properties as well as the marketing direction this product is intended to satisfy. I suggested to Dr. G that I’d like to do an independent test on my new company car to see if this product is as good as everyone claims. He showed a moderate amount of interest at 1st, but when I told him that I’d only be washing only with Dawn dish soap & harsh Touchless car washes he became even more awakened to say the least. To add fuel to the fire, I told him that I’d only be applying the product to ½ the vehicle and the paint on the factory hood would be sanded flat to test the product’s UV ability. We’ll, the rest is history…..
Here are the particulars on the car. 2010 Ford Fusion – Silver clear coat metallic. I contacted my sales rep@ Plantation Ford (Plantation, FL) to insist that nobody lay a single hand on my car except the Tech to do the mechanical prepping. This one came 100% defect free.
Here’s how it beaded with ZERO protection:
Top horizontal place of the hood was sanded 95% flat. I used 3M 1500 Trizact(wet) with my Porter Cable XP on speed 3.5. This clear is ROCK HARD & I ended up going through 5 discs of paper on just the hood!! I then refined the 1500 with 3M 3000 grit Trizact(wet).
I then removed the sand scratches with Meg’s M105 via Lake Country Cyan (blue) by PC using the Kevin Brown Method (KBM). I then followed with Meg’s M205 via CL White via PC too.
50/50 Sanded Shots:
As you can see, there is quite a large difference in texture after the sanding process. I’m anxious to see if any premature failure occurs (on either side) as this car will be parked 100% outside and runs at least 8 hours per day, 5 days a week in the hot S. Florida climate!
Orange Peel (no sanding):
Orange Peel (after sanding):
PREP PROCESS
Beading with M205 oils:
Dawn Wash:
Soaking:
Beading after Dawn:
AM Blue Clay Magic (H2O Flush Technique):
Optimum Power Clean (totally killed beading):
No More Beading after Power Clean:
Alcohol Wipe Down:
The Driver’s Side of vehicle was taped off for application of the sealant:
Tools used for application of the Coating:
Coating was applied to every square inch of the Driver’s side of vehicle (paint/chrome/trim/glass):
After the coating was allowed to “set up”, the tape was removed and the residual was wiped towards/into the applied section. This was to cut down the “hard line” and to not cross contaminate the uncoated side (to eliminate a sque result).
This is what the coating looks like after it’s completely dry. I used a product dampened applicator and pushed down on an inconspicuous area of the back glass. This product is literally like an epoxy-like coating of glass. This will be interesting to watch as time goes on:
After coating is applied:
Here’s 1 of the 2 ways this vehicle will be washed. The other will be with Dawn.
As you can see, after roughly 1 month beading is very strong:
Frost on car:
Rain sitting on dirty finish:
I’ll keep posting results every few months as the testing continues……..
WOWOWOW! Cool!
I can't wait to see how this turns out!
I have a feeling this will be epic!
That is a product you don't hear about everyday! Do you find application any more difficult than a normal wax or sealant?
Optimum RULES!!!!!!! :props: :iagree:
Can you tell that I use Optimum as my primary product? he he he
btw - Nice work on the Fusion. I wish my dads Ford-Lincoln-Mercury Dealership would let me do that.
Very well written and explained write-up Dave. Tests like this are more valuable with great documentation. It takes time to document any process including both capturing pictures that tell a story and then adding the words to help explain the story told by the pictures.
:xyxthumbs:
:iagree: :props:
:xyxthumbs:
WOW! Great Stuff. I wait with eager anticipation on further results.
Thank you for doing this cool test for us I will have to subscribe to this post.
Wow...I wont have the guts to do that to a new car. This might be a silly question - what is the logic behind sanding the car?
"and the paint on the factory hood would be sanded flat to test the product’s UV ability"
How would sanding down the paint help prove the product's UV ability? Not trying to be an ass - innocent question...trying to understand..
My best guess is to see how the clearcoat withstands the elements on the unprotected side. This would test the paint's durability while giving you an honest indication of how it will react under the worst possible scenario of zero protection. The next most likely is to remove orange peel which a lot of American cars have plenty of these days.
Great test and documentation! That un-coated side looks so sad and lonely :cry:. I understand going to a brush-less auto wash, but WHY are you going to continue to wash with Dawn? Trying to give Opti-Coat a hard time to see if it lasts I assume.
Thanks for the write up, wish I was the one doing it. :xyxthumbs:
Thank you for doing this, look forward to your findings.
Joe Fernandez of superior shine put opti coat on my 03 z06 back in June of last year. I have an 07 z06 now, but opti coat was great on the 03!
I am very interested in this test. I have some Opti-Coat and am wondering if I should use it on both vehicles. We have an 07 Charcoal Expedition and an 05 XLR in Xenon Blue. I enjoy keeping them looking. great. I currently use BFWD over the Menzerna Twins and am happy with the look, I dont know if O-C can look as good as BFWD. I know it will act moe like an invisible bra than an ISP.
