Setec Astronomy
- Aug 31, 2010
- 17,176
- 1,471
It's still a bit confusing. As I understand it the formula of Opti-Lens is designed to bond specifically with the materials of the lens, not the clear-coat that may be over it. Thus my question.
You're getting confused with Opti-Glass, which is different than Opti-Coat and is designed to adhere to silica surfaces. Opti-Lens is very similar to Opti-Coat but with more UV inhibitors.
From earlier in this thread:
A new car is the best application for any coating. A optimum Finish or Polish II is the minimum prep, it's just to make sure the surface is clean and smooth so the bond will be with the surface and thus, permanent. Neither Polish II, Hyper Polish, nor Finish will marr. As long as your not using wool or a dirty pad![]()
I think you're getting a little too wound up, take some time and read this whole thread and I think you will feel better.
