ScottB
- Mar 3, 2006
- 18,803
- Thread starter
- #81
Waxmax said:If Opti-Seal is similar to Z-CS it it will be a winner. The hardest thing with ZCS is to "see" where you've applied it and go thin. I spritz a panel, then wipe/spread it, then lightly go to-fro on horizontals, up down on verticles. It is super easy to apply. Some areas may have a "rainbow"/hologram look, but in 15-30 minutes it self levels and disappears. Any spot hazing easily can be QD'd out. I've use ZCS to top XMT360, AJ, Z5/Z2, and cured carnauba. As orngez said, many manufacturers will be looking at this techinolgy, if they are not already.
I am hoping for more gloss with Opti-seal, the CS is much to sterile looking and plain. That said I found it easy to see where I went. The CS has a light hologram look until it dries, you can notice it much easier when looking off center.
