Its interesting that nobody from Palm Beach Motoring/Autogeek can chime in here.
This thread was started on Monday. This would be the day I returned to work after SEMA was over. I got home late Saturday night, around 11:45PM, kind of tired after the week and the long flight.
Took Sunday off.
Spent Monday playing catch up. Lots of catch-up. Can't possibly reply to every thread started since I left Stuart on Sunday, November 3rd. I do post a lot and I do try to reply to as may threads as possible but I couldn't get to this on Monday and yesterday, (Tuesday, November 12th), I was out most of the day shoot a new segment for Ship Shape TV. When I did return to the office I had quite a bit of work to do to get this going,
2013 Dodge Charger - LIVE BROADCAST - Black Label & Rupes Polishers
2013 Pearl Jazz Blue Dodge Charger
I didn't order the paint cleansing lotion. I am planning to use it on a car that will be receiving a full paint correction...I know how to do proper prep work before applying a coating but in the description for the PBD coating it says "If you do not use Surface Cleansing Polish before applying one of the Diamond coatings, the result will be complete failure of the coating"
So do I now need to buy the cleansing polish and use it even with all the other prep work being done? Feed back please
I didn't write the copy for that page nor did I work on the creation of this product but my guess would be that since that's a store page it's speaking to a lot more people than the educated people that hang out on this forum. Imagine for a second that a lot of NON-forum people find that page and all the info they have is from that page. They don't hang out on a forum like this and get the overload of deep thinking that goes on every day but people that are for the most part OCD when it comes to prep work for a coating.
For these people, you need to be very clear and specific because it's quite possible the store page is the only place and time where you're going to have a chance to educate them on how to properly use ANY product.
"By creating a polish that doesn’t have any oils, waxes, silicones, polymers or fillers, you can apply a paint coating immediately after polishing your paint with Detailer’s Coating Prep Polish. There is no need to chemically strip the paint using Isopropyl alcohol or volatile wax and oil removers.
This is an excerpt taken from the DP prep polish page.
So if I use opti-eraser shouldn't the surface be clean enough for the coating?
Here's the "issue" with all the other liquids commonly used to prep or chemically strip paint to remove any oils or other substances before applying any other coating and that is most of these other solvents are not good lubricants. So while they may clean the surface they may also introduce marring during the application and removal process.
I go over this in detail in this thread dated before Erasure and any product introduced after Erasure were introduced to the market. Point being what I wrote was accurate not only at the time I wrote it but even up to today.
Here's the article,
Hologram Free with a Rotary Buffer
Here's the pertinent part...
Now you can see some light marring, but that's because IPA isn't a very good lubricant, in fact it's a
horrible lubricant. I think of all the people that have been told by others to wipe their car down with IPA before going to the next step and it's pretty easy to understand that when they did this they likely marred their car's paint and this is called
working backwards. It's also likely that if the people taking this advice were working on light to medium colored cars they never saw the marring.
And while you might only see this on black or dark colored paints, if it's happening to the CLEAR layer on top of black and dark colored paints isn't it happening to all paints even if you cannot see it?
The DP Coating Prep Polish and the Black Label Surface Cleansing Polish offer more lubrication for the surface prepping polish than most other solvents.
As far as I know, the key thing with the application of ANY coating is that the surface needs to be free from any oils, waxes, fillers or silicones in order for the ingredients in ANY coating to properly bond to the paint.
In the context of car wax history, which I document and explain in my how-to book is only around 100 years old, coatings and how we prep paint for coatings is still new territory.
I'm sure there's more to learn moving into the future.
