Here's a little tip, anytime you're buffing next to an adjacent panel and it's possible you could run the vertical or side edge of your pad into the paint, lubricate it by working some of the product you're using on the face of the pad onto and into the foam. This will help to keep from generating too much heat and burning the paint and also in the case of these lower panels, help me to remove some of the sanding marks on the angled section.
It's this little long thin section I'm trying to improve and protect.
Jacob said:The rain gutters needed polishing as well. Marc applied both M105 and M205 to foam applicators and squeezed it into the gutter to polish.
Jacob said:For the Camaro we opted to use a wax appropriate for the vehicle:
jlb85 said:The flat black trim was dressed with Meg’s Spray Trim Detailer and a soft brush, then buffed even. Mike Phillips from Meguiar’s (now at AutoGeek) recommended me to use this product on flat back a few years ago and it never fails. It evens out even more as it dries further.
Applied to the bumper trim as well:
Many THANKS again to Jacob & Marc for the outstanding transformation of our GTO! It was a pleasure to watch these guys do there thing and see the end result.
True professionals to the max. Thanks again guys for the great job!!!!
Stu
