Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 12
- Thread starter
- #41
Continued....
After all the paint correction and sealing was finished, next up we sealed the vinyl top using 303 Protectant. The top had been washed, cleaned and dried first thing in the morning so now the vinyl is perfectly prepared for the 303 protectant.
Technique Tip
Because the paint, glass and trim have all been polished and sealed, to avoid getting overspray onto these surfaces and then having to wipe them again, here's a techniquie tip, it's real simple but as I always say,
The little things are the big things
To avoid overspray, simply bury the nozzle into a microfiber applicator pad and INJECT the 303 Protectant INTO the foam core inside the applicator pad. This gets the product onto and into the pad.
Then as you press the applicator against the vinyl top the foam core will release the product and you have zero overspray on the car.
Product Tip
Correctly applied you lay down a WET APPLICATION. This means use a lot of product to saturate the vinyl and then massage it into the vinyl.
After thoroughly massaging the 303 Protectant INTO and over the vinyl top - next wipe the top dry using clean, dry microfiber towels.
Done!
Technique Tip
Product Tip
Done!
