Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 7
Plastic Restoration 101 with Solution Finish - Do it yourself - Save Time - Save Money!
At my 3-day Competition Ready Detailing Classes I cover a lot of topics and one of them is how to correctly restore faded plastic trim. The key is to clean the plastic really well first and then treat the plastic with the proper products and after restoring the trim periodically maintain the trim to maintain its appearance value.
My good friend Chris West sent me some information to share how his product, Solution Finish works to restore the color to faded, oxidized plastic trim.
Now if you look at the various sections of plastic cladding in the pictures, just like Chris stated, the plastic comes from 6 different companies and some components fade differently than other components. Just want to point this out as it's very apparent in the pictures and shows that Chris really knows his business.
Sean and Chelsea removing the hard plastic tonneau cover...
Demonstration: How to apply and work in Solution Finish
Using a black wheel and tire microfiber towel to wipe off any excess.
Removing the painter's tape....
Boom! There it is...
Hands on training and real-world experience restoring plastic trim with Solution Finish.
And here are the results.....
Here's what the owner said when he picked her up....
Truck looks amazing!
Get Solution Finish and restore the plastic trim on your car, truck or suv today!
At Autogeek.com
Solution Finish Super Size Exterior Trim Kit
Restore faded moldings and trim with precision!
The Solution Finish Precision Trim Kit is designed to restore those narrow pieces of trim around the windows and wipers. The included finger pocket enables you to apply Solution Finish neatly to any small area. Restore the black color and sheen to faded plastic, rubber, and vinyl with this easy, three-step kit.
The Solution Finish Precision Trim Kit includes:
12 oz. Solution Finish Black Plastic & Vinyl Restorer
Solution Finish is ideal for restoring, conditioning and protecting any originally black surfaces. Solution Finish dries quickly with no greasy residue. This unique formula combines ancient ingredients with advanced polymer technology to provide a spectacular, long-lasting, black, protective finish. It is silicone-free and VOC compliant.
4 oz. Denatured Alcohol
Clean the desired area with alcohol to remove all dirt and oils. Foreign substances can inhibit Solution Finish's ability to bond evenly to the surface. Prepare the surface first by wiping it with an alcohol-moistened microfiber pad.
2 Latex Gloves
Keep your hands clean while applying Solution Finish. These gloves are one size fits all.
2 Microfiber Applicators
These soft applicators are perfect for applying Solution Finish to running boards, bumpers, and other wider trim pieces. Reserve one to buff off excess Solution Finish after application. Wash in microfiber detergent and reuse.
Microfiber Towel, 16 x 16 inches
Use this microfiber towel to clean the desired area with alcohol before applying Solution Finish. The towel is made of durable, absorbent microfiber with more than 100 fibers per square inch. Wash in microfiber detergent and reuse.
Foam Finger Pocket
Use this finger pocket to apply Solution Finish to the wiper cowl, narrow trim, and the black edging around car windows.
Chris West said:Hello Mike, I can't tell you how much I appreciate your support with Solution Finish and I am honored that you would include it in your workshop.
Here are a few tips and tricks, along with some technical information that maybe your students would find interesting.
First of all, Solution Finish is not an ink, dye, or stain – it is solvent-based modified black carbon.
Solution Finish does 3 very important things that are different than your typical plastic dressing:
1) Because it's solvent-based, it actually dissolves the existing oxidation on the plastic part.
2) It puts the black carbon back into the microscopic pores of the part being treated.
3) It contains antioxidants and light stabilizers that prevent the UV radiation from further oxidizing the trim.
What I’ve done is milled the carbon 7 times, making it as small as a virus – so with our modified and penetrating oil, it is able to draw the black carbon deep into the pores of the plastic.
In silicone-based products, the molecules are too “fat” (as we call it) to do anything other than coat the surface – a Band-Aid, if you will.
Pure plastic does not oxidize – it's the impurities and additives in the plastic that actually break down and cause the oxidation process to start.
When silicone starts breaking down and gasses off, it creates a hydro-peroxide gas which actually accelerates the oxidation process. Once that happens, it doesn't stop unless you prevent the gasses from forming; Solution Finish does just that.
Regarding the Avalanche you’re going to be detailing, it's interesting to note that the truck has 6 different manufacturers of plastics to on the vehicle. The running boards, quarter panels, bed cover, cab extensions, bumper covers and tailgate cap are all made by different companies.
Therefore, they all are susceptible to deterioration in different ways. But, as you will see, Solution Finish brings the black back and keeps it there.
At Autogeek.com
2 Latex Gloves
Foam Finger Pocket
