Hi guys,
So I've been detailing my own car, first time detailing, it's a HONDA CRV Nighthawkblack. I've run over the car with Megs UC + Orange LC pad, see to go well, bit of dusting, bit of sticky residue, but learning to manage them, but having trouble using HD POLISH.
The DA Polisher I'm using is a CONCOUR 900 polisher, no sure what RPM each number is, but having been getting advice from another detailer who has detailed a few HONDA Black vehicles.
https://www.zas.com.au/product/601/concours_900_dual_action_polisher.html
Using the DA + Orange LC pad, I apply 3x pea drops on the outter edge of the pad, work it into the paint, then up the speed to 3x for 3 passes (as recommended), went well.
Now with the polishing, I used HD POLISH with an LC White pad, I primed the pad (using QD as I don't have much HD Polish available), applied 3x pea drops to the out. Did the same as previously, but, it leaves residue easily on the paint that is very hard to remove with a MF towel, even using some QG to help. I try going over again with the polisher, helps list if a little, but not a lot. I have to use etra pressure from the MF towel to remove the residue, but can leave light swirls.
I switch to a Black LC polishing pad, but was just as pad (if not slightly worse)
I got to the point and juse decided to use the WHITE LC Polish pad + Megs UC, and that worked fine, the panels are shiny.. probably not as shiny is I used a specific polish, but it heaps better than before washing/correcting.
Any thoughts on what I did wrong? perhaps others have used HD polish with good/bad results, though from reading, many many people seem to praise HD, so maybe it was to do with me.
Ideas ?
I watched a 3 part video of Mike detailing a black car (with Wolfgang products?, Porter Cable DA & LC Pads), though his suggestions were different. He mentioned using speeds of 5-6 for Correcting, 3-4 for polishing and maybe 3 for waxing. He also did 4-6 passes (but also a lot more product.. unless excess product was just used mainly to prime the pad??)
Dual Action Orbital Polisher Guide: how to remove swirls, scratches, & oxidation with an orbital buffer. Porter Cable 7424, foam pads, backing plate,
(part 2 cut out, found part 3 on youtube)
Suggestions ?
Ideas ?
Suggestions ?
