PA DETAILER
- Mar 5, 2011
- 6,008
- 238
I'll go ahead and say placebo product, just like the others..
It'll most likely just leave a sufactant behind to mask the LSP properties..
Between high solvents, hi alkaline, , pH balanced,acid, and polish.. the only ones to strip away protection is polish and acid with enough wipe downs..that's it..I've even recently tried a ph14 product (Fbomb) with no dissolving going on.
there's a big difference between a chunk of wax in a cup and a microscopically thin layer on your car, also it doesn't have to dissolve the wax it only has to break the bond to your car.
I agree.I'll go ahead and say placebo product, just like the others..
I just think it's not conclusive to many variables. You can strip a wax with these products if it's been on for a little.
If you are ending up with salt and pepper dots I would say that means it's breaking it apart?
No those are what's im carving it up to by using the serrations from a knife. Those thin lil dots arnt being dissolved by anything but acid
Ph nuetral, high solvents, nor high alkaline arnt breaking them down..
Wax will break down in a cup of acid easily..but takes more than a couple panel wipes with acid to strip an LSP
I'll buy some and donmy own testing..
I say give it the next morning and see if it still has lack of sheeting or if it'll bead/sheet again
I had meguiars wash plus+ do that
I say give it the next morning and see if it still has lack of sheeting or if it'll bead/sheet againhttps://www.autogeekonline.net/forum/newreply.php?do=newreply&p=1577911
