DARK HORSE
Active member
- Sep 14, 2009
- 2,537
I recently purchased a pc xp; it came with a white polishing pad that is already permanetly attached to some kind of backing plate. My question is does any one no if this is a quality pad? I have several other CCS and Hydrotech pads, so I don't want to use this pad if it's not as good as the other pads I already have.. Also it came with a small spacer; does anyone know if it is necassary to use this spacer, and if so when. I used the pc last week for the first time and I did not use the spacer. I used both the 5" and the 3.5" backing plates and did not seem to need the spacer, is this correct?
