Rob, you will be happy you did! Did you get a gallon. Ive used over a qt of concentrate so far! I may retire my Bug Remover products!Just placed an order for Opti-Clean. Too much positive feedback to not give it a try.
Earlier today I cleaned Sky's engine, door seal, and door jambs with OOC. Use to use ONR-QD for this.
Also been using OOC to remove the fresh bugs off the front of my car after a drive.
I only snapped a couple pics as I wasn't necessarily planning on posting at the time.
You are correct Rob. Its a steal IMO!Just placed an order for Opti-Clean. Too much positive feedback to not give it a try.
Cee Dog, what do you use on the plastic parts in your engine compartment? And, is it the same as what you use for your interior?
Cliff
I believe you answered your own question Jenn.So what is the difference between Opti-clean and OID? I know one is a cleaner and the other is a detailer, but in my mind they both seem to be used the same way except the Opti-clean seems like more of a waterless wash
Yes it would be much better that ONR @ QD Strength for bird bombs. Spray on, let sit, then wipe carefully!
