Quick tip regarding wet/dry vacuum filters
Eldorado2k
I’ve been testing this out for the past 3 weeks and I’ve decided it’s something that some people might find beneficial, so I’m going to share my experience along with a few pics.
What is it? It’s called a Pool Skimmer Sock.
What’s it do? Off label use. Works as a pre filter for my Ridgid wet/dry vacs filter.
You can find them online for very cheap. I bought a 30 pack for $14.99. I bought the Aiglam brand ones and FYI, right now I see them priced @$12.99
My Ridgid is a 14 gallon vacuum so it uses the taller filters that you see in the pics. I know alot of people use the 4 gallon Ridgid vac that uses different size filters and I do not know the dimensions of those filters so I don’t know if these socks will fit those, you’ll have to research that yourself.
Make sure you check the dimensions of the socks before you buy, as I’ve noticed some sellers offer cheaper price listings but the socks are also smaller and some people report that those smaller socks don’t fit the filter properly, so check the dimensions before you buy.
These are the dimensions for the full size socks that fit my vacs filters. 8x4.5” and they stretch to fit. [The smaller ones are like 6.5” in length and won’t fit properly]
So how well does this work? Well I can say it works ok/ pretty well and I think some people would say it works pretty darn great and I can understand why… Check out what it looks like opening my vacuum after 3 weeks of good use.
Normally I’d have to go through my process of putting the filter into a kitchen trash bag and beating the dirt out of it for a while, followed by rinsing it with the garden hose and letting it dry in the sun.
But the convenience of this method is all I had to do is quickly remove the sock into the trash bin and give the filter a couple of quick bangs inside the bin and it’s serviceable once again without the effort of having to clean it.
Is it perfect? Far from perfect. Is it serviceable? Yes it is.
Just put a new pool sock on and we’re ready to rock & roll.
Pros:
-It’s inexpensive
-Doesn’t affect the suction at all
-Cuts the filter cleanup time down to a fraction of what it usually takes
-The socks are washable and reusable if you decide to be El Cheapo about it
Cons: And this may mess with your OCD…
-How much will it bother you if you don’t get your filter as clean as possible in between emptyings of the canister?
It all depends on whether that even matters to you aka OCD. Filter type also plays a factor because i.e. my filter is a CleanStream hepa filter and they say you’re not supposed to use compressed air to clean it so I don’t have the option to use my blower on it whereas you can use air if you have the Rifgid blue filter along with other filters.
That’s the only con I see so far, but as you can see it’s sort of a minor con.
Hopefully some people reading this will find this useful for their vacuums. Thanks for reading.
Very cool idea, Ric.
Nice write-up too. :props:
What about Admiral? :laughing::laughing:
I guess most can be cheap, but I can really be cheap. And my wife hates it because she says “you never want to spend a penny.” I want to tell her “yeah for every dollar I spend on my stuff you want to spend three. So, for the record she doesn’t see half of what I spend due to my creative finances. Four years of accounting will either get you in trouble (got a friend in trouble now and I believe will end up being “away” trouble) or help you manage your finances so your wife believes you are a cheapo…I’m the latter. But I do like this sock.
So I would extend that one to Fleet Admiral cheapo. LOL
Another great tip, and your writeup was very well done.
Funny thing. I have an old Genie-brand "shop vac" that I use for my cars because it is small/convenient but powerful for its size. It's factory filtration system consists of something quite similar to your pool sock.
Great tip Eldo !!! I have some skimmer socks sitting out in my pool bin that I am not using so I am excited to try this. I actually stopped using the skimmer socks on my pool because they restricted the water flow a bit based on their density when they got dirty. Someone on one of the pool forums suggested using simple hair nets used by food prep workers. Voila...they are perfect and I use them all the time in my pool skimmers.
Now I can find a use for my skimmer socks I am not using :)
Thanks for the tip, Eldo.
I've been doing the same thing for years, using "Plus Size" Women's "Knee Highs", kinda a much shorter version of ladies stockings. You're right in that it drastically reduces filter cleaning intervals as well as the mess. I have to check these out and see how they compare.
Avoiding shopping in the "Plus Size" section of the ladies lingerie department would be a bonus!
Bill
Love it!
Almost have to wonder why someone at Rigid or Shop-Vac, etc. didn't think about this and offer it as an option.
Thank you for sharing!
Ridgid does sell dust bags which act as a prefilter but they're much more expensive. Maybe they didn't want to cut into their filter sales?
I'll have to look into this for the smaller Ridgid filter.
I use bags in combination with the green Ridgid HEPA filter on my 4gal 5hp, so my filter stays clean very easily. But maybe I'll try this out once I use the rest of them up. Cool tip! :xyxthumbs:
Is it OK to wash a non-washable filter? For this reason alone I find this a great idea
What do you mean exactly? They’re all washable.. Well you don’t really “wash” them, you just rinse them with water.
The only thing I don’t like about my Cleanstream Hepa filter is that it says not to use high powered air on it because it might remove an important layer off of it. But otherwise you can rinse and blow the filters clean.
Like a K&N is made to be washed and re-used, others are one time use.
That's a great idea. My filter gets just like the one you showed. Thanks for the idea.
Sent from my SM-G955U using Tapatalk
Picked up some of these for the smaller Ridgid filter on my WD4070. These were advertised as 4.5 x 6". They were more like 4 x 7.5" but they seem to fit. It was 30 for 12.99 but were temporarily discounted to 10.39. there was some stretching at the top to get enough slack to pull it down the sides. A bit like putting on a fitted bed sheet.
Thanks for providing the update for the users with that vacuum.
