recommendations for steamers under/around $100
Did you hit the underhood pad with steam? A guy on another Forum turned me on to Armor All Tire Foam for underhood pads after you get any serious grunge off... has some decent cleaning properties and they come out looking like new.
TL
I won't lie ...i ran out of steam and didnt wanna wait for it to heat back up to do the pads...i did the painted area and the grill area below the windshield wipers and just wanted to show that...but didn't have enough to get to the pads and by the time i had finished i had other things i had to go do...this was a freebie for a friend so not like i cut corners :nomore:.
Ill keep that in mind though...i'll see how the pads turn out with the steam (might try it this weekend or something) and then see how my dressing works..and if its not so good then i might try the foam.
The McCulloch and the Wagner are the EXACT same, they are made by SteamFast.
The only difference is the attachments that they come with. You can order the attachments from Steamfast if you feel that you need them.
