Remove the glare from where you stare
Window Glare!
Both annoying as well as a safety issue
I don't know anyone that likes glare on their windshield. Glare is how light is diffused over the surface making it hard to see. It's also a safety issue because you need to see when you're driving.
Common problem
While writing a recent article about Griot's Fine Glass Polish I noticed the inside of my own glass had a film build-up. Over the years I've seen questions come up on our forum where people are having a difficult time removing really stubborn films and contamination off the INSIDE of their windows. Normally they tell a tale of how they've used every glass cleaner under the sun and every secret glass cleaning technique ever shared over the blogosphere.
Vinyl Fog
New cars have a lot of plastic and other freshly made man-made components and materials inside of them. These newly manufactured parts will tend to give off a chemical gas called outgassing as a natural process. This can also be accentuated when interiors become hot, for example parking outside in a parking lot in full sun with all the windows rolled up. The inside can become a sort of pressure cooker. The resulting outgassing deposits an oily film on the inside of the car. It's probably everywhere since it's not picky about where it attaches but it's only on the glass that you can see it.
Sometimes you need a mechanical solution (no pun intended)
I've come across difficult inside windows to clean in my lifetime and when I've exhausted normal spray-on glass cleaners I've switched over to polishes with great success. The idea being to use a glass polish to cut through the gunk on the glass and then wipe this residue off.
How it works?
The abrasives in the glass polish plus any chemical cleaners will cut through the film and then mix into the polish itself.
Then you wipe the whole mess off.
Next switch back over to your favorite spray-on glass cleaner to make the final wipes. While it can be awkward rubbing some type of applicator pad over the inside of your car's glass unless you're already a contortionist, with a little effort you can do it.
Capturing glare with a camera
I've taken thousands of pictures in my car detailing life documenting defects an all types of surfaces but when I went to take pictures of the glare caused by a film that has built-up on the inside of my truck I found it to be a little tricky. It was tricky to capture both the glare and film before and also after. But I think when you look at the pictures below you'll agree, somehow I did it.
The challenge of timing
First you have to get the pictures either early in the morning as the sun is coming up or late in the afternoon as the sun is setting. After looking at the glare at both times of the day I decided it would be better to capture early morning pictures.
Here's a shot looking out the driver's side of my truck's windshield...
Here's a cropped out section from the above picture...
Here's a full size image, 800 pixels wide cropped out of the original.
Soft foam applicator pad...
I applied to just a section of glass in the middle of the windshield.
This morning, I arrived to work early to capture the before and after 50/50 shots as the sun was rising on the horizon....
Now you have to look carefully
The inside glass on the left side has been hand polished with Griot's Fine Glass Polish and the inside glass on the right side is untouched.
The smear you see is where I took my finger and swiped it across the glass before I started writing this article just out of curiosity to see how bad the film on the glass was...
Sun Glare and the Multiplier Effect
It's the FILM on the inside of your car's glass that multiplies the GLARE created from sun rays hitting the windshield that blinds you while you're driving.
Finishing the job...
Today I finished hand polishing the entire inside glass...
Now that's a clear view!
Summary...
So if you find yourself struggling to really get the inside glass on your car clean... it might be time to take a new approach and hand polish the glass with a dedicated glass polish.
What a transformation Mike! Doesn't look like there is a windshield in the truck.
Wife has been after me to clean the inside of the front window. I think its time I get it polished.
Thanks for sharing.
Damn Mike, that is truly amazing. Thanks a bunch for coming into to work early. I don't have any of Griots but I have CarPro's CeriGlass. I am going to try this today.
I've had good success with a 1-1 ratio of Vinegar & Water for cutting film & haze off glass. Just make sure you spray onto the towel first and then apply to the glass. Use recommended glass towels for both application and second wipe removal. Try it, think you'll like it.
Excellent info Mike. I've wondered what the next step in interior glass cleaning was.
:dblthumb2:
WOW!
Wish this was posted a few days ago so I could have added it to my already un-needed order from Cyber Monday LOL.
Mike, would Wolfgang Perfekt Vision Glass Polish be a good candidate to get the same result as above?
Just ordered a bottle.
I never really gave glass polishing much thought because they don't ever really get nasty.
I have hit them with polish before but not a specific glass polish.
Using Invinsible Glass on the interior aftermarket tint works great.
Thanks for sharing.
Better clean the inside windows and keep the wife happy.
CarPro's CeriGlass will work the same way.
Wow, great 50/50 demo!
Thanks Mike. Pain to photograph.
Awesome Mike! That's a great tip!
Thank you sir.
It's the polish - a creamy substance, mixing with the icky stuff on the glass and then absorbing it into itself and then wiping the entire mess off that is the secret.
:dblthumb2:
WOW!
That's funny... :)
Might. What I wrote about was when a person runs into stubborn film where traditional spray-on glass cleaners were NOT working. So asking is a traditional spray-on glass cleaner will work kind of doesn't fit the scenario I presented but sure, go ahead and try. If you still have stubborn film that your fighting to get off then try this approach.
Can this process be used if there's a tint installed?
No and absolutely NO.
This glass polish, like all the glass polishes I know of and have used have some form of abrasive technology and the abrasive technology would probably scratch the hell out of the soft, malleable plastic.
Thanks for asking the question.
Using Invisible Glass on the interior aftermarket tint works great.
Agree. Stick with spray-on glass cleaners without ammonia for interior tinted windows.
Mike, I was referencing this product: Wolfgang Perfekt Vision Glass Polish polishes and restores auto glass windshields and windows.
Maybe not the intended subject, but the photography skills is what really impressed me in this article. My wife had the need to try to show some detail in a photograph recently. Very difficult to do what you did without a very good skill set.
The whole time I read this I kept thinking about your recent posts on the subject of skill v. products in paint correction. Do you ever compare the value of your skill set in paint correction v. photography. I don't mean in a dollar sense. But, rather to do the quality of work you do. Which presently requires the higher skill set?
Oh, and have you ever thought about writing a book on car photography? Both to teach getting the best pictures and work documentation.
Hi RatZ1LLa,
The answer is "yes".
Both products use glass-safe abrasive technology and both will remove stubborn road film, smoker's film, vinyl fog and water spots.
Just don't use on film tinted windows.
Dear Mike,
My jaw is still in the floor from those jaw dropping photos.
Well done!
Thanks Dan...
Of course the pictures of me using the light were taken by a standerby? Don't remember who.
I use a Canon Rebel T5i
I find this model difficult to use. I started out with the T1i, then the T2i and then the T3i and then the T4i and now this current version. I tend to wear out cameras and I take lots of pictures in my job.
For what it's worth, I think I might also post more pictures "inserted" into threads in the car detailing world than any other "instructor" or person in general. Some of my threads or articles have over 100 pictures.
I use the camera on the P mode or Priority Aperture Mode. Then adjust the exposure per the car. Also use Automatic White Balance for pictures in the garage and the florescent light setting.
I'm actually not a photographer and have very little knowledge of the craft and art itself, just do a lot of it since discussion forums were invented.
I've never compared the value of my skill set in paint correction versus photography, I just know it's important to be able to do both.
One of the most important articles I've ever written was an article to TRY to help other detailers by teaching them the importance and the value of getting GREAT before pictures.
Check out the title of this article and after thinking about it I'm confident most of you would agree with the title.
The power in the after shots is created in the before shots
Um... no.... I don't feel even remotely qualified to write a professionally sourced book about photography. There are thousands of real photographers that would laugh at anything I wrote.
With some work I could probably write a how to book on How to photograph cars for car detailing" or something like that but there are so many cameras and the location and lighting and even background color of the walls in the location are such huge and varied factors.
Thanks for the compliment but for now I have some other books I'm working on...
If you wear out cameras that fast, you may want to consider stepping up the the "prosumer" level (80D) with your next one. The bodies on them have many of the features, and protections from moisture, that the pro level gear has with the ease of use of the rebel family.
