Removing leather smell from new car
How long did you ozone the car?
I tried that on the very first car, but the dealer said we shouldn't do it for more than an hour or two or we'd risk damaging (oxidizing) the electronics.
I wonder what happens to, or what the interior "materials" will look like, after all of the off-gassing has taken place during the 'normal-life-expectancy' of an interior's materials...
Let alone when this aging process has been accelerated by a 'Baking Method'?
And is the TSP mentioned above: Tri-sodium Phosphate?...A banned chemical in over 20 States and partially banned in more than 15 others!!!
A hazardous material rating of 3: High/Serious...For health&safety!!
I personally wouldn't recommend TSP's usage for/on anything, or by anyone!!!
Got to also wonder if this is the first new vehicle the OP has ever 'owned'...Out-gassing sensitivities surely would have been made self-evident, prior to this report, if that is indeed the case.
If the OP says it's leather causing his "problems", then I will not argue his position. Except for what I posted previously, that is.
I had a customer come to me with the same issue once before. I had no idea what to do. So, I stuck my ozone machine in it for a while. I smelled it afterwards....and I could have sworn the smell was still there.
But, when the customer came to pick it up...he was psyched that I got rid of it, ha. So, I guess it worked...:dunno:
DCertainly the VOC's, glues, and other chemicals used in the manufacture of the car contribute to the problem. But, they dissipate pretty quickly (usually 1-6 months) if you leave the windows open and air out the car regularly, what's left is the fragrance from the leather seats.
My experience has been that regularly cleaning that leather reduces its odor. The odor you smell in a leather vehicle is not the natural smell of the hide, but the odor of the chemicals used to treat it. Nowadays, most leather manufacturers actually add frangrances specifically to give the leather an ordor, and it is in the "paint" that actually sits on the surface of the automotive leather.
The "new car smell" that we all crave is actually caused by the various materials in the car out gassing. The strong smells should dissipate over time. I would not be scrubbing the leather to rid the odor. You are only opening up the pores even more if it is real leather and compromising the integrity of the leather itself. You may want to see if Car Pro's So2Pure can give you some relief.
To me:
Your latest posts seem contradictory from what you originally posted. :confused:
Could I be mistaken?
Just curious...
If you already knew of your "leather-sensitivities"...Why would you have another vehicle with leather appointments?
This works well for odor removal and not just coverup. Buy two boxes and put them under your seats. Odors should be gone win a weeks time.
If I had your problem with migraines attributed to new car/leather smells I'd simply be in the market for a super nice 2 year old certified pre-owned car every few years instead of buying new. Seems to be a real simple solution. If new cars give you headaches then don't buy new cars.
I'm not seeing a contradiction in my messages.
The reason that I still purchase cars despite the issues that I have is that I need transportation to get around.
The reason that I buy cars with leather is because:
1. I have the same issues with cloth seats, just for a shorter time period,
2. Vehicles with leather interiors tend to be larger and safer, have more safety features, and more luxury appointments that I'd like to have,
3. I haven't given up on trying to find either a medical solution or a way to eliminate the odor (hence my post here), and
4. Once leather vehicles lose their odor, they are much better choices than cloth for a variety of reasons. Among other things,
a. they can be cleaned without introducing fragrances. If you truly want to clean a cloth seat, you pretty much have to use a shampoo type product which leaves a residue inside the cloth and foam and which smells for years. A leather or vinyl seat can be easily cleaned with a general purpose cleaner.
b. They are also resistant to other things: One time, I had a mechanic who worked under my dashboard with his armpit on the cloth seat, and the cloth seat absorbed massive amounts of his sweat. The car smelled like BO for weeks. After trying to clean it 4x, the dealer ultimately swapped out the entire seat. Leather is also easier to clean up spills. Imagine if someone spilled perfume on a cloth seat. You'd never get the smell out.
There are a number of reasons that I don't buy used cars. I actually tried purchasing several used vehicles with mixed results.
The first one turned out to be a women and smoker's car and had been "bombed" by the dealership. The result of the "bomb" was to cover up the smoke smell for the first few days, but after about a week, the car reeked of perfume and cigarette smoke. The effect was as bad as a new car with leather, except that in addition to having headaches, I found the odor objectionable as well. I actually like the smell of leather, in that it smells good.
In another case, I purchased a used vehicle from a dealer that detailed it by shampooing the carpet using a rub in, leave in shampoo that itself had a strong fragrance. It took me about two weeks to figure out where the smell was coming from. It took four rinses with a steam extractor to get the carpet truly clean, and another year before the odor went away completely.
There are all sorts of other issues with used cars, including the risk that the prior owner used an air freshener, spilled a bottle of perfume somewhere, or sprayed febreze all over the interior (very common nowadays - as most people thing Febreze kills odors (it doesn't)).
And that doesn't even get into the risk that the prior owner might not have changed the oil as often as he should have, or redlined the car a lot, or gotten into an accident. The accident issue can be identified by a good mechanic, but its almost impossible to determine if the prior owner has an oil sludge issue without pulling the oil pan, and finding evidence of abusive driving is almost impossible.
All in all, new cars are the better choice.
Which gets back to my original question: Can anyone recommend a good mechanical device that I can use to clean the leather so that my hands don't get tired?
To me:
Just curious...
That's true. You can't leave it in there for too long supposively. I left it in for almost two hours though. I always put the ozone in the back, away from the electronics as much as possible.
I've never had issues frying electronics. Although, I noticed once that while the ozone was on....it would interfere with radio reception. That's about it. Once I turned it off...radio was fine.
Sent from my ADR6350 using Tapatalk
Removing the leather smell,from my expierence cleaning neglected cars is simple.
#1 -get a dog to ride around everywhere with you
#2 -put some restaurant leftovers in the styrofoam container in the backseat and leave it there.
#3 - take up smoking and only smoke in you car
To me:
Contradictions or otherwise (You see things your way...I see things mine):
my hand starts to hurt after a while with all the scrubbing.
Can anyone recommend some kind of mechanical/electrical device that I could use to make the cleaning process easier?
As far as recommending any good mechanical devices to alleviate the:
1.) "my hand starts to hurt after a while with all the scrubbing"; and...
2.) "so my hands don't get tired".
I try to give advice/recommendations based on Joaquin de Sentanti's quote in my signature line...
So, then:
No! I will not give advice, for any mechanical devices, in order for anyone to be assisted in "scrubbing leather". This is not a Best Practice in maintaining/protecting leather appointments/surfaces, IMHO.
(This way, I can't be asked to shoulder any "blame" for any persons vehicle attaining a: Dismal interior appearance; or, a sizable reduction in a vehicle's resale value.)
Sorry that you have such sensitivities, though.
Hope the Drs. can get to their root-cause someday.
They did for some of my allergies!
