Sorry, I should have been more specific about the products I used.
The compound I used by hand is
DuPont One Step Polish 1500s. This is a professional product used in paint shops. The only number I could find that might be a part number is 2RF-010CBCS-048-0789.
The other product I have is DuPont Highlighting Glaze 3000S. The only number I could find is 2RF-001GBDS-048-0290.
Both products indicate for hand or machine application (1500 - 2200 RPM by machine - I assume rotary).
My understanding is that the 1500 and 3000 are respectively equivalent to 1500 and 3000 grit paper.
I just did a google search on the 1500S One Step Polish and found a Technical Data Sheet from 2003
[FONT=TimesNewRoman,Bold]Properties[/FONT]
- Removes 600S compound marks and P1500 sand scratches, without leaving swirl marks.
- Does not dry up on the job.
- Easy clean up of residue with water.
I'm pretty connected to the paitn polishing world and just don't ever see these products talked about, I have to wonder if they're even available any longer?
Technology has chaged a lot and continues to change as I type... if these products get you to where you want to be then that's all that's important, if you ever get to where you're looking for something new to try then we can help you there too...
If the 1500s will remove 1500 grit sanding marks by machine or hand then it's an aggressive compuond and how it finishes out is the most important aspect. M105 will remove #1200 and finish out to it looks like you just waxed the paint. Big change in abrasive technology when this product was introduced.
I am not looking for a show car finish. This vehicle lives outside, I just want it looking reasonable good without any water spots.
Thanks for all of the relies and suggestions,
John
Do some testing with your Porter Cable and some of the recommendation already posted... if the PC won't do the job then you might have to switch to a rotary buffer.
You really need to get some M105 and some 5.5" aggressive pads, either foam or the SurBuff.
Surbuf MicroFinger Buffing Pads now at Autogeek!
Surbuf R Series 4 Inch Buffing Pads 2 Pack
Surbuf R Series 5.5 Inch Buffing Pads 2 Pack
Surbuf R Series 6.5 Inch Buffing Pads 2 Pack
We were shooting a video on how to
Machine Damp Sand using Meguiar's Unigrit #3000 Foam Finishing Discs and then how to remove your sanding marks using a rotary buffer and took a moment to show that if you choose, you can also use a DA Polisher with Surbuf MicroFinger buffing Pads to remove shallow sanding marks like those left by the #3000 Unigrit Foam Finishing Discs and a compound.
Just to note, for years now, the question about whether the you can use a DA Polisher, like the
Porter Cable 7424XP, the
Meguiar's G110v2 or the
Griot's Garage ROP to remove sanding marks out of modern clear coat paint has been a hot topic.
While there are a number of factors involved that affect a "Yes" or "No" answer, generally speaking you can remove light or shallow sanding marks out of clear coat finished using a DA Style Polisher with their
Free Rotating Spindle Assemblies for drive mechanisms, you just need to use the right pads, products and techniques. Top Coat Hardness is a huge factor when it comes to determining whether or not a DA Style Polisher can remove sanding marks and this will vary between cars.
While the most effective way is still by using a direct drive, rotary buffer with a cutting pad and a compound, especially if you sanding down an entire car, we demonstrated using the Surbuf MicroFinger Buffing Pads with a
SMAT product like M105 you can easily remove a controlled sanding mark pattern, in this example, #3000 Unigrit Foam Finishing Papers by Meguiar's were used. Autogeek will have the new Unigrit Foam Finishing Discs very soon. Stay tuned for an upcoming article on this topic.
This is our project car. This is a restored and mild hotrod 1969 El Camino with a custom basecoat/clearcoat finish. The fit and finish of the panels is excellent and the paint application came out very nice, there are a few leftover sanding marks in the paint and rotary buffer swirls including
arc scratches probably from an abrasive particle being trapped between the pad and the paint. Our goal is to remove all the below surface defects and restore a true show car shine.
We moved the car out into the sun where the bright overhead sunlight can reveal the true condition of the paint.
Next we'll Machine Damp Sand the deep swirls and scratches until the surface is flat using the new Meguiar's Unigrit Professional Finishing System.
The section below was sanded using the #3000 Unigrit Foam Finishing Disc on the Meguiar's G110v2 on the 5.0 Speed Setting for about 5-6 Section Passes.
We moved the car back out into the sun to show just how
flat of a sanding mark pattern the Unigrit Foam Finishing Papers leave behind and this is because of the Unigrit
particle size and
distribution of these particles over the face of each disc; two very important factors that make removing sanding marks quick and easy.
A very flat or matte appearance
In person, the paint actually has a
sheen to it as it's just a quick step away from a polished look because the sanding marks are so shallow and flat...
Back in the garage under the lights, you can see the Damp-Sanded area and the swirls and scratches in the rest of the paint.
Here are the results after Machine Compounding using the Surbuf MicroFinger Buffing Pads on the Meguiar's G110v2 on the 6.0 Speed Setting with M105 Ultra Compound for about 5-6 Section passes.
We followed this with M205 Ultra Finishing Polish on a W9207 Foam Finishing pad on the 5.0 Speed Setting using the G110v2 for about 4 passes with medium pressure and then two more section passes with just a little more than the weight of the machine to keep the pad flat to the surface. The results you see here are only after polishing with M205, there is no wax or paint sealant applied at this point.
The test section was also wiped clean using straight
Mineral Spirits to remove any residual polishing oils.
Note the Dime in this picture carefully placed onto the paint
Close-up to show there are no sanding marks left on the surface, no tick marks or haze. There is a spec of dust just to the lower left hand corner off to the side of the dime that we left there to show just how close we are to the paint when taking this picture.
This paint is LSP ready.
On the Autogeek.net Website
