How would BF One step work with Lake Country Microfiber Polishing pads?
It will work great.
What you're supposed to do before buffing out an entire car is called..... drum roll......
TEST SPOT
Do a Test Spot, this will tell show you the results from the pad, product, tool and your technique. If it looks GREAT - then repeat the Test Spot process over the rest of the car. If it looks like cr*p - then test something else.
Great question!
to do a 30' travel trailer in the spring.
What is the surface for this travel trailer?
Paint?
Gelcoat?
Something else?
If it's gel-coat you can probably get always with microfiber pads.
But like paint - do a Test Spot.
That's a lot of real-estate to have to do over if you don't get it right the first time.
It is painted Fiberglass. I will have to do probably 4 test spots (one for each side) to be on the safe side because the oxidation level varies.
If the paint is truly oxidized (chalky/powdery looking) you might consider giving it the "Comet Cleanser" treatment before attempting to polish with the AIO. That will remove most of the dead paint before you ever put your pad to the paint and will help your pad go much farther as the pad will not get so gummed/loaded up as quickly.
Hi Mike I applied BF one step one time about 2 months ago....my machine....and I am happy using....
can I use it like every 2 months
