I just ordered a sample bottle this last sale. The car has very lite swirls and I'm hoping this will take care of those. I have a PC but going to try first by hand as the swirls are not that bad. Looking forward to receiving.
IMO, the difference between the 7424xp and gg6 is minimal at best.
Polishing in direct sunlight is never a good idea.
Way too many factors that may give you results less than desirable.
Great points, Mike.I agree. However, if you're a mobile detailer sometimes you don't have any options. Working in the sun not only includes people that detail cars but also these huge monstrosities that often times are NOT under cover.
- Boats
- RVs
- Airplanes/Jets
For anyone that has to detail in full sun, been there, done that, here are two things I do that help me.
First - start as early as you can in the morning, even working before the sun comes up for things like washing a car.
Second - Anytime you're buffing on paint - SHRINK THE SIZE OF THE AREA YOU WORK DOWN TO SMALLER SIZE.
By shrinking your work size area down as you move the polisher over the surface you'll keep the product you're using more liquid since you'll be agitating it more. If you buff a large section, while you're on one side of the section buffing the product on the other side is drying up on you.
It can seem like you'll go slower by working smaller sections but it's seriously a case of going slower to go faster.
Plus you won't wear yourself out as much trying to wipe off dried product.
Here's an article I wrote 8 years ago on this topic, look at the time stamp...
Tips for working in warm/hot weather or direct sunlight
I would apply any conventional wax or sealant over it.
I regularly use SONAX PNS over it.
So is it ok to use the Black Fire SI02 after using the One Step?
I do. In fact I used the Blackfire SI02 over BLACKFIRE One Step on a Maserati this last Saturday. Results were stunning!
Next day I topped with Pinnacle Black Label Surface Coating - took the results to and even darker, more clear results. Check it out...
Stunning results Mike.
I wouldn't have thought about a coating over something like SiO2. Interesting.
Wait until you see my write-up. This Maserati was recently painted. When it arrived here it was filled with sanding marks and holograms. The paint was on the soft side. I removed the sanding marks using BLACKFIRE Compound and a white foam polishing pad --> with ease.
Sometimes I break the rules. I love Pinnacle Black Label Surface Coating, it's very easy to use, creates that glassy look and leaves the paint slippery feeling, not rubbery feeling like a lot of coatings.
Apparently, I'm very good at resurrecting old threads. I'm sorry. Just wanted to obtain some clarification and I see this was brought up a few a pages ago.
I seem to recall in other places in the forum here that AIO's should be utilized solely with a polishing pad... yet, this particular review, it looks like an orange cutting pad was used. I was under the impression from previous reading that the use of a cutting pad with an AIO would / could result in micro-marring and/or haze. Is this not the case? Is it product specific?
I'm currently using a Griot's 6" DA and my go-to AIO has been McKee's 360 using LC thin pro white polishing pads.
Could I safely utilize the orange cutting pad with McKee's 360? I thought that was a no-no.
Could anyone lend any clarification?
Never worry about bring an old thread back to life. Actually, in context this is NOT and old thread. It's all good.
