otruba_843
- Mar 3, 2012
- 288
I have used this product for the past 3 months on my car and I do like it. I was using Meg's endurance tire gel and did like it, but it leaves a gross film on your tire after a week of driving. This tire gel is a lot easier to remove with APC, but stays on just as long. Since it is water based, you can use it on plastic trim etc. It has been on my engine for 3 months and it still looks great! Stay tuned for pictures through out the week till the next wash.
Pros:
1. Smells like cherry but not an overpowering cherry
2. It is water based
3. Very easy to apply
4. Good durability (will put it to the test again over the week)
5. Absolutely no sling what so ever and no need to wipe it down after application
6. It can be layered for more shine
Cons:
1. It does come fly off on the applicator a little before it is actually applied (this happens because it has a very air like consistency, but no big deal if you don't go around the tire fast in the beginning)
Tires were cleaned with APC+ and a stiff bristle brush before application.
Bottle:
Note: Hard to capture the color right, but it is a light pink.
Before:
After (only applied one coat):
Pros:
Cons:
Bottle:
Before:
