Can you use a rinseless wash like blackfire/DP/Optimum as a water conditioner to add lubricity in your normal wash bucket (A regular wash with regular auto shampoo and an ounce or two of rinseless wash thrown in) and then use Reload on the car or will the reload not stick because the rinseless washes had polymers/lubricants etc in them. (I want to use the reload over my opti-guarded car)
regarding your first question about adding rinseless wash solution to your wash bucket.. yes, you can do it, but it absolutely kills the suds and the lathery feeling of your shampoo. Everytime I have tested this, it usually always makes the shampoo mixture less effective IME. So i personally avoid mixing the two. Try Optimum carwash at the instructed dilution on the bottle 1oz/1gallon, and you will end up with a super safe, super slippery/, extremely effective lather that i personally think cant be beat.
you can use reload over opti-gaurd. It actually works great with opti-coatings. you just have to be careful not to overuse reload. a little bit spreads extremely far. its more oily than other spray wax's so its important not to drench a panel and having a few extra MF's on hand will help. Because of how thick/oily reload is I prefer to put it into a 4oz pump sprayer to apply it instead of the big headed sprayer bottle.
I agree it's a suds killer. However, if you suffer from hard water, an ounce or less will help in that regard.
you can use it on your freshly paint, i guess passed 2 weeks dry from the day it was painted.
should be ok, no problem at all.
